It is currently Mon Aug 24, 2026 1:13 pm
 Post subject: Impress me with your mech troubleshooting skill
PostPosted: Thu Oct 11, 2001 4:02 am
Scenario goes
1. car runs over bump, or thru a pothole
2. a thump, thump, thump starts to happen that is consistent with vehicle speed ie slower speed, slower rhythm of thumps
3. no wear marks anywhere, like if a exhaust was hitting DS
4. happens in all gears 1st-reverse, clutch in or out, in gear or out. Doesnt change when do 360deg turns or K turns.
what do you think:
1. DS lost a weight
2. ring and pinion gone south
3. something wrong with axles
4. tranny headed for the bone heap
5. tranny mount broke (not noticeably broken or split BTW)
PostPosted: Thu Oct 11, 2001 6:00 am
I'd go with #5, and I think George is experiencing the same thing!!!! ;) :(
PostPosted: Thu Oct 11, 2001 1:29 pm
#2 but It could be a rear bearing? but that is not a choice??? how loud is it?
PostPosted: Thu Oct 11, 2001 2:01 pm
Mine thumps only when I get on it and experience wheel hop...
What about a bent rim? Is it a thump felt in the wheel?
PostPosted: Thu Oct 11, 2001 2:33 pm
George my 3 inch pipe that goes over the rear end was scrubing the diff making the sound you discribed. I Welded it problem fixed.
 Post subject: definate
PostPosted: Thu Oct 11, 2001 2:42 pm
#########22222
PostPosted: Thu Oct 11, 2001 3:38 pm
I have looked and looked... I have no exhaust rub.. The sound and feel is from the tranny area... I think poly will fix it..
PostPosted: Thu Oct 11, 2001 3:50 pm
It took me 1 year to find it I heard it on the bumps. I bet it started when you fixed your cat or installed the loud mouth. I could be wrong just trying to help?
PostPosted: Thu Oct 11, 2001 8:41 pm
Mine does not do it when going over bumps, or when shocks are moving.. Mine slams the bottom of the car. I will let you feel it next time we are together. It is almost for sure the stock tranny mount.....
PostPosted: Fri Oct 12, 2001 3:55 am
Well, not only have I never seen something like this, I've never read about it either. Apparantly there was a bolt, and I mean a real, 1/4" at least bolt in the rear diff case!!! When I hit the pothole, it bounced the bolt up into the ring and pinion, and wedged it between the ring gear, and the posi unit. Literally cold welding it in place. After beating the hell out of it, cleaning out the thousands of metal particles, and 2qts of synth, its running quiet as a stocker. Another bonus, is I ran the part number on the ring gear, and it turns out the previous owner (had the car for 2 months, then $$$ problems took over) was misinformed, or silly, cuz the gears are 4.10's not 3.73's. Look out 1.7 60's!!!!!
I took it out tonight and ran it from a stop thru 4 gears in anger, and everything held togethor. Looks like the track night tomarrow is back on (if this rain storm leaves:( ).
I just wished I had known why it was doing this last night, then I wouldnt have order the FMS Driveshaft, SVO rear girdle, and tranny mount in a fit of rage :-ok:. Oh well, what the wife doesnt know, wont hurt me!!!!
I got to give it up for the 8.8, they are some kinda stout piece of work.
Later
Users browsing this forum: No registered users and 35 guests
