It is currently Sat Feb 21, 2026 5:02 pm
 Post subject: who knows this one??
PostPosted: Thu Oct 11, 2001 11:50 am
I was talking to this guy today. And we were talking about a cheap solution to fix my car until I have the money to do it the rest of the way.
Here goes Can you use a 383 crank without boring out the cylinders. If you can what do you need besides the crank to due it??? And if you can due it it should set the engine up as a 377 instead of a 350. I'm not sure of this one so maybe one of you will.
PostPosted: Thu Oct 11, 2001 12:08 pm
that number sounds weird, kinda like your putting a mopar in!
anyway, my take on this, is it wont be like installing a CAI, or changing plugs, this is pretty major work. I am not willing, or near smart enough to make a opinion on if it will work, but if it does, you still have commited yourself to 2 complete teardowns.
Just seems to me, it would be easier/cheaper and more than likely if the time was added up, faster to do it the way you'd like it the first time.
but heck, if they can put a 327 crank in a 289 to make a 305, I'm sure you can do a 383 crank in a a 350.
 Post subject: Sounds
PostPosted: Thu Oct 11, 2001 12:23 pm
like it should work. But your right Rob I have put a lot of time into tear downs. If this will work I'm also going to replace the pistons and just do a full rebuild. The only thing i'm trying to avoid is paying a $1000.00 or more having my block bored out. It's all about money and daycare is taking 900 a month (ouch).
PostPosted: Thu Oct 11, 2001 12:49 pm
If you are going to rebuild it needs to be bored. There is a place in Trier that will do it for approx. DM 700 for 8 cylinders. The only thing I'm not sure about is other block clearancing needed. Hope this helps you out. Do you ever answer e-mails?
PostPosted: Thu Oct 11, 2001 1:18 pm
Here is my .02 cents!!! It will work without boring if block is in perfect shape which I doubt due to oil pressure problems you had? =377 must have 400 crank, balancer and flywheel which will be diffrent externally balanced? And you may run into clutch clearance problems. Best deal buy the complete 400 SB and put your heads and cam induction, ignition in it all that would be required is a head gasket kit. Then you would have a 400 LT1. Or maybe some one is selling theirs in the club summer is over and alot of people are doing build ups this winter? Mix matching internal rotating engine pieces without machine work is trouble.
 Post subject: ok
PostPosted: Thu Oct 11, 2001 2:04 pm
first dave sorry man i've been really busy. I'll write you back tonight with your question?
Bruce I agree with you that it will work. The 383 crank is actually a 400 crank yes/no. As far as piston clearance boring out your engine does nothing for the piston to head clearance. When you bore out the block your just increasing the size of the piston your using right/wrong. I know I may have to change some things in the engine but it shouldn't be to bad. Keep the good info coming I know this is somthing not to many people do but that makes me want to do it even more.
PostPosted: Thu Oct 11, 2001 2:12 pm
The boring only increases the cubes a little. The real increase is created with the longer stroke which is why some clearancing is needed (even on 383). But like I said before, parts only for rotating assymbly COMPLETELY FORGED is $1975.00. No insult in intellect meant.
PostPosted: Thu Oct 11, 2001 2:20 pm
first it is a 400 crank with a std block =377 2nd A .30 overbore larger pistons.=383 and there is some clearance work that needs to be done with the block and or crank.
 Post subject: The
PostPosted: Thu Oct 11, 2001 2:38 pm
You should be able to clear up the clearance with new connecting rods. If you use the forged connecting rods used when building a normal 383 I should work. I'm pretty sure that the stock connecting rods will be to long and It might smack the heads. In my mind I can't see why this wouldn't work because how high the piston travels has nothing to do with the bore size on the cylinders. I know I can check how high the piston travels with silly puddy and putting the head back on but I'm trying to by the right stuff the first time. We all know how this goes!!!! the waiting for parts sucks over here!!!!!keep the info flowing need as much as I can get.
 Post subject: Hey
PostPosted: Thu Oct 11, 2001 7:13 pm
Dave you said 700dm for boring out a 350 MORE INFO
 Post subject: Hey Ryan...
PostPosted: Thu Oct 11, 2001 8:35 pm
Why don't you just sell that POS!!! Your it....
 Post subject: Mike you little
PostPosted: Thu Oct 11, 2001 10:42 pm
Piece of shi$!!!! what's up man how have you been. I know your just living it up on the tracks.
Tag your it Here you go 5000 miles away trashing my topic that's ok I have something in store for you.
MIKE SAYS HE HATES THE FIREBIRD LINE UP AND TRANS AM LINE UP. J/K SHOOT ME YOUR NUMBER AGAIN.
 Post subject: Ryan...
PostPosted: Thu Oct 11, 2001 11:49 pm
Which number do you want dude? Man, 3 months tax free, hazardous duty, and a $30,000 re-enlistment bonus. I am not going to know what to do with myself...
 Post subject: straight up knuckle head
PostPosted: Fri Oct 12, 2001 1:27 am
#1. Ha Ha what ever happened to not reelisting????? UNCLE SAM HAS YOU. It just goes to show you an F-body is like a woman they'll make you do weird and crazy things.j/k I know if they offered me all that money I would jump on that offer. You should have a pretty mean ass SS after all that dough. What are the future plans for your car now that all that money came into play.
#2. I was talking about your PHONE NUMBER.
#3. Did you get your car yet if so how was it when you picked it up? Did that cat I give you work for the inspection both from and to. Talk to you later.
PostPosted: Fri Oct 12, 2001 6:16 am
Well not nesessarily a 350 but DM 700 for 8 cylinders. One of my friends blew up his honda and had it bored out twice and the total came to DM 700. I don't know the specifics, but I can find out.
PostPosted: Fri Oct 12, 2001 6:54 am
I sent you a e-mail on this Ryan. But a few more thoughts came to mind....
For pistons some great inexspensive ones that I have seen are TRW forged slugs. I have seen these pistons in more magazines than I can remember shake off more nitrous than you can shake a stick at.(Especially 440 mopar build up, 300Hp NOS hit, gaskets went but pistons didnt, but you know those old mopars!) Also PAW might have some good prices on 383 kits.
 Post subject: Jeff, Dave
PostPosted: Sun Oct 14, 2001 7:16 am
Jeff i'm checking my mail I'm going to look into those pistons if they save a little money I'm all for it.
Dave you said they bored out a honda 4cyl two times total of 8cyl for 700dm. I wonder if they'll charge more due to the bigger cyl walls. good info shoot me your number so I can give you a call. I have it not sure where though.
PostPosted: Sun Oct 14, 2001 3:39 pm
No problem. 06565-944114. I need to call the dude that got this done. As far as an increase in price for bigger walls, not sure. I'll hook you up best I can.
