It is currently Tue Aug 25, 2026 7:51 am
 Post subject: inspection question
PostPosted: Thu May 08, 2008 8:28 am
I'm going to be getting to spang around the end of july. is there any wear that has the requirements for the inspection there...exhaust db mainly, just want to know if ill have to do any thing to my car before i ship it off.
-Tony
1993 Z28;A4,.008shavedheads,Borla Adj catback,CAI,3.73 gears,Trick flow Elbow,Taylor 8.2 wires,NGK plugs,Pacesetter,UMI brackets,Spohn LCA, Spohn panhard,ZR1's
http://www.fquick.com/towshen
 Post subject: Re: inspection question
PostPosted: Thu May 08, 2008 9:08 am
First, welcome to the area and FBE!
Here is the actual regulation.
http://rmv.hqusareur.army.mil/190-1/ss190-1.htm
Pay attention to how the Db level is read. They are currently allowing the level to go beyond the regulation to 95Db. It is measured about 3 feet from the tailpipe at a 45 degree angle (IIRC). The car is then revved to 1/2 redline to take the reading.
I can tell you that Kooks LT's w/o cats to a closed Borla will net a 98.8 Db. So, I think you will be vey close and may be able to make it as you are.
Some other hot topics are window tint (can't have it on the sid or windshield glass), tire tread (must be above the wear bars with even wear) and ball joints/sterring system. Also, all lights (even fogs) must be operational if they are on the car. Finally, you have to have a good spare and also must get a first aide kit and triangle. Let me know if you need anything else.
Last edited by Chevroletfreak on Thu May 08, 2008 9:24 am, edited 2 times in total.
PostPosted: Thu May 08, 2008 9:13 am
Oh yeah, that is so cool that there is a 93 coming in to replace a 93 leaving. SRZ is a 93 and he is on his way out the door (unfortunately). Also, the previous toy that I had here was 93Z that I owned for 5 years. So, i've got the 93 knowledge if you need anything.
PostPosted: Thu May 08, 2008 9:53 am
Tony! Sup? Follow Brian's advice and you'll be good to go. IF you can throw a cat on there before shipping it'll be even better in helping reduce your DB level. Too bad I'll miss ya but you are in good hands around here.
Silas,
The "SRZ"
PostPosted: Thu May 08, 2008 1:08 pm
i have a full exhaust system on there, including a cat. and the link dose not work for me! before i ship the car i'm going to go through it with a fine tooth comb. all my suspension should be good since i did it all about a year and a half ago, but the car has been sitting in my parents garage for the past year. i mainly wanted to know about the exhaust stuff since people are trying to tell me that if i got a after market system i WILL fail.
and thank you for the info!
-Tony
PostPosted: Thu May 08, 2008 2:08 pm
I think your exhaust will be good to go as is.
PostPosted: Fri May 09, 2008 8:47 am
got another question. one of my friends who is also going to spangdahlem has a newer dodge ram and hes got his exhaust dumped just in front of the rear axle, will he need to either extend it to the rear bumper or kick it out the side?
PostPosted: Fri May 09, 2008 11:01 am
Absolutely! They won't pass that.
Don't just take my word for it though. Get ahold of the regulation. I have no idea why the link won't work for you.
PostPosted: Fri May 09, 2008 12:09 pm
i got the reg now(emailed it to me at work and worked fine...stupid Korean internet!!!). and thats kinda what i figured he would need to do.
PostPosted: Sat May 10, 2008 2:33 pm
got another quick question. has there been a lot of cases where stereos disappear out of cars shipping through the AF?
PostPosted: Sat May 10, 2008 8:35 pm
All 3 of my cars that I shipped got some new scratches. 1 was mil shipped and 2 were private. The only other thing I lost was an SS dash plaque and that was through private ship.
