It is currently Mon Aug 24, 2026 8:29 am
 Post subject: Tranny problems
PostPosted: Tue Jun 19, 2007 6:20 am
It dosent like going into 4th at high speed like if I am going from the top of third it will go into gear then pop out and wont stay same if I try to down shift on the autobahn doing around 90. Any other time it is fine. SO should I start looking into a rebuild?
PostPosted: Tue Jun 19, 2007 6:34 am
Start with the simple stuff
Does it have an aftermarket shifter with external shift stops?
PostPosted: Tue Jun 19, 2007 6:47 am
Hmm did ya check you tranny fluid? Or the kickdown may be of to.
PostPosted: Tue Jun 19, 2007 6:52 am
Stock shifter.
PostPosted: Tue Jun 19, 2007 9:27 am
Sometimes its hard to tell , But the 3/4 shiftfork will bend and cause that problem , bit so will a bad 3/4 synchronizer and blocking rings.
PostPosted: Mon Jul 02, 2007 8:32 am
Like Roy said, I would start with the simple stuff. I would replace the tranny fluid with some synthetic stuff, the PX has Royal Purple. You will need a good pump syphon. I just changed mine this weekend, found out that I was down about a quart, and I had notchy shifting as well beforehand, even after swapping the shifter to the new C6 Z06 shifter, so the notchiness was from the tranny. After swapping the fluid It is easier to shift and I am still evaluating if my tranny should go under the knife. If It does, then I will use one from RPMtranmissions.com. Overall, it is less notchy. Even better fluid is the AMSOL synthetic, which is raved about in the states for the both the racing and street crowd. It will take 2 months to get here via slow boat if yo do order some though.
Good luck,
Nick
PostPosted: Mon Jul 02, 2007 8:40 am
Upps bad mistake I thought he had a auto.
PostPosted: Mon Jul 02, 2007 8:43 am
Nope the auto is in my 98
PostPosted: Mon Jul 02, 2007 1:32 pm
Tranny needs to be rebuilt. Sorry to hear it man.
PostPosted: Mon Jul 09, 2007 8:29 am
Chris I sent you a pm. Tell your boy it's doubled since he wasted my time...I didn't have to pull it off in the 1st place.
The "SRZ"
PostPosted: Mon Jul 09, 2007 9:09 am
I got you sorry again
PostPosted: Tue Jul 17, 2007 4:20 pm
Sup w/ ya boy Chris does he want it or not? Original asking price but he needs to decide or I'm junkin it.
PostPosted: Tue Jul 17, 2007 4:29 pm
So did you get it fixed? What are ya gonna do?
PostPosted: Wed Jul 18, 2007 6:12 am
I have done anything with it because of the accedent. But I will wait till I get back to the states.
PostPosted: Sat Jul 21, 2007 10:01 pm
Dude before you go for a rebuild when back in the states DO make sure that you have enough fluid... it makes a difference...
1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
