It is currently Mon Aug 24, 2026 3:11 am
 Post subject: Need ABS help
PostPosted: Mon Mar 18, 2002 9:01 pm
I am trying to get that light ABS INOP out off my dash. I would like to have ABS up front and bypass the back has anybody heard of how I could do this? Thanks
PostPosted: Tue Mar 19, 2002 6:00 am
Bruce what do you have 3channel or4 channel ABS?
PostPosted: Tue Mar 19, 2002 8:33 am
I have 1 sensor 2 wires that used to go in the top of the old rear. Tried splicing them together and it worked till I moved the car. The ABS still seems to work in the front tried that this morning.
PostPosted: Tue Mar 19, 2002 9:43 am
Bruce
That would be the 3 channel system. The system will never work properly with out the proper number of teeth and spacing on the reluctor ring .
with out the proper signal , the ABS will never work properly.
Alot of 3 channel operators are pulling the abs unit completely and adding a combination valve with an adjustable proportioning valve.
As for the light ,pull the bulb.
Also you might wanto brush up on tthe term thresh holdbraking.
Mental note : do not ride with Bruce on a Banzai blitz down the Autobahn.
PostPosted: Tue Mar 19, 2002 12:17 pm
Thanks
I am going out this afternoon to slam the brakes. It seems to stop straight not as efficent it pulses about 1/2 what it did. I think you would like the setup I got - the no ABS.
