It is currently Mon Aug 24, 2026 11:11 am
 Post subject: New Cam
PostPosted: Wed Jun 30, 2004 9:28 am
seems like it will be ok
PostPosted: Thu Jul 01, 2004 4:05 am
well Goood for you I guess. :o
PostPosted: Fri Jul 02, 2004 7:01 am
It is pretty easy in the LS1.
PostPosted: Fri Jul 02, 2004 2:50 pm
whats the specs on it.
PostPosted: Mon Jul 05, 2004 3:04 pm
237-242 dur @.50 and 595/595 on a 112 LSA sounds good and it loves RPM's
PostPosted: Mon Jul 05, 2004 5:00 pm
Yeah I would gues in the low7000 shift range for that or the high 6000 range :shock:
PostPosted: Mon Jul 05, 2004 5:12 pm
I also installed these trick dual patriot valve springs with super 7 locks and titanium retainers. feels like it has a bit more up top.
PostPosted: Mon Jul 05, 2004 8:51 pm
this cam seems a bit less aggressive down low but makes up the diffrence + some @ 7000 RPM's I would go higher but I get scarred and it gets loud. Got the rev limit set @ 7100.
PostPosted: Tue Jul 06, 2004 4:28 am
:shock:
PostPosted: Sun Jul 11, 2004 8:26 am
You get skurred? :shock: I don't believe that. :?
Anyway, I can't wait to hear it!
PostPosted: Sun Jul 11, 2004 8:37 am
It lopes hard and since the knock senser is fixed It sinks my eyeballs in my head.
PostPosted: Sun Jul 11, 2004 10:12 am
Hey, what do you torque the rocker arms to?
PostPosted: Sun Jul 11, 2004 10:23 am
30 knewton meters. And you gotta hold the rocker straight in the middle of the valve.
PostPosted: Sun Jul 11, 2004 8:49 pm
Thanks dood! ;)
