It is currently Tue Aug 25, 2026 2:15 am
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2, 3  Next
 Post subject: LPE GT 2-3 CAM, install help
PostPosted: Thu Sep 22, 2005 1:05 pm
So who is going to help me install an LPE cam?
I'm going to be up front and let you all know that I have hardly any mechanical know how, but I learn fast.
Need someone to help me work through the cam install.
I will be moving to the Schweinfurt area in the next month.
I don't have the cam yet but should have it come winter.
8)
PostPosted: Thu Sep 22, 2005 1:09 pm
I plan on running that same cam here soon I think because it will be nice with me procharger. :twisted: On that note I have never done a cam install myself but there are plenty of guys who have. You could always go to http://www.ls1howto.com for all the info you need on doing a cam swap. If I was closer I would help so we could both learn. Crash course on your car. :D
PostPosted: Thu Sep 22, 2005 1:39 pm
Actually LPE has another cam that they suggest for FI. The GT2-3 is supposed to be an N/A cam.
PostPosted: Thu Sep 22, 2005 2:24 pm
I'll help you but I won' be back until mid november. If you can't wait that long contact Bruce. He helped me install mine when I was an LS1 newbie. He is moving up to Bamberg at the beginning of October.
PostPosted: Thu Sep 22, 2005 2:25 pm
Oh I left some important info out about Bruce. Just make sure you start in the morning and work during the day. He wussed out on me at about 4 a.m. I had to fix the valves he didn't adjust correctly with him snoring in a chair. :D
PostPosted: Thu Sep 22, 2005 3:01 pm
Umm, yeah, I am not a wrencher at all, so this is going to be a slow 'hold my hand' process.
:oops:
PostPosted: Thu Sep 22, 2005 6:16 pm
Not a problem. Hardest part is getting the balancer off. You might want to think about an underdrive pulley since we will already have it off.
PostPosted: Thu Sep 22, 2005 7:45 pm
If you do a search a lot of people actually run the GT2-3 with boost and have great results. I have not decided on anything abosolute yet though.
PostPosted: Fri Sep 23, 2005 6:24 am
Well I am looking forward to it. Hoping for 360/360 with a dyno tune and 345-350 without.
:twisted:
PostPosted: Fri Sep 23, 2005 6:25 am
I've heard bad things about the UD draining your battery.
I know some people say it is fine but others say they can clearly see it affecting the car at night with lights on and radio on.
PostPosted: Fri Sep 23, 2005 6:39 am
Those are the guys with larger than average radios.
PostPosted: Fri Sep 23, 2005 7:13 am
When my car was relatively stock with an underdrive pulley I did see a dip in charging but it was no big deal. I really only saw it with the radio, heater, and headlights on. I now have an ATI one but my car idles at 900rpm so it’s no problem either.
PostPosted: Fri Sep 23, 2005 3:41 pm
I think ASP sells the underdrive pulley with an overdriven alternator pulley. It is cheaper than the single SLP crank pulley and I have heard good things about it. I know it will not work if you ever decided to install a double roller timing chain. You would have to get the end turned down some but any good machine shop could do it.
PostPosted: Sun Sep 25, 2005 8:54 am
sure I could help you it is pretty straight foward. One question what are You doing about a tune? UD pullies are a good idea if you drive on the a-bahn like me. I have destroyed 2 power steering pumps and 3 altenators they give up to the ghost pretty quick around 7000 RPM.
PostPosted: Sun Sep 25, 2005 9:17 am
Tune is going to be done by RWTD.
I've also asked Ligenfelter and a few people who are currently running the cam and they say you can run it without a tune for a while, pretty mild.
PostPosted: Sun Sep 25, 2005 12:07 pm
Val firechicken has a TR224 for sale with CC918 springs and titanium retainers for cheap.
PostPosted: Mon Sep 26, 2005 6:29 pm
This kit comes with the LS6 springs, supposedly that is all you need....
PostPosted: Mon Oct 03, 2005 8:43 pm
Alright, cam selection has changed.
I am now deciding between a custom cam that will be slightly more aggressive than the GT 2-3 Cam (something that takes advantage of my exhaust work).
Cost of this custom cam will be $450 (+ $200 for a good valvetrain upgrade), or I can get some Stage III P&P'd heads with valvetrain upgrades for $1299 shipped.
Decisions, decisions....
30-35 rwhp from a cam or 25-30 rwhp from some heads.
Only issue is that the heads will allow for some great gains once I do get a cam....
Help me out, what would you do?
Full Bassani Exhaust
AEM Meth Injection
PostPosted: Mon Oct 03, 2005 11:10 pm
Just do heads and cam at the same time. Match them up now and just make it easier in the long run. True you might have to wait a little because it will be more but you will be better off in the long run.
PostPosted: Tue Oct 04, 2005 4:33 am
I would do the cam first and get a good computer tune. That made the biggest difference on my car. Do you have headers on the car yet?
