It is currently Tue Aug 25, 2026 3:02 am
 Post subject: What do you guys think?
PostPosted: Thu Oct 25, 2001 11:45 pm
This is from AFR:
Dear Mike,
            We do not do porting on  any other heads other then our own. We do make
our own 195 cc LT-4 head fully CNC ported 2.02 intake 1.60 exhaust. Flowing 262.
CFM intake and 194 CFM exhaust combustion chambers size any from 56 to 74 cc you
decide. The springs are rated to .550 lift HYD roller. the heads cost $1750 complete ready
to bolt-on. Thank you for your interest in our cylinder heads. Please feel free to call with any
questions that you may have. 818-890-0616.
  Sincerely,
    Marc R
    Sales Tech.
Does this include rockers??? Good deal or what?? (74cc Bigger is better?) Give me some input guys. Guess I might sell my heads...Thanx in advance, Mike
PostPosted: Fri Oct 26, 2001 12:25 am
I cannot tell you about the specs, but sell yours and get them. You can sell yours for more than the cost of the core......
PostPosted: Fri Oct 26, 2001 12:33 am
Yeah, I don't know either, but if that's what you want, and you can't find anyone else to do it, sell 'em and get 'em... You should try to find someone to do it though, 'cause I'm sure it would be hella cheaper..
PostPosted: Fri Oct 26, 2001 5:54 am
Those are the same ones I was looking at but can't afford right now. They do not come with the rockers, but they are complete heads. I don't believe any head manufacturer sells heads including the rockers. I would deffinitely recomend them and when I get the money, I will be getting probably those same ones.
 Post subject: Mike
PostPosted: Fri Oct 26, 2001 4:41 pm
Hey man that's a pretty good deal considering the LT4 heads are usually 689.00 a piece and a good port job will cost close to a $1000.00. As far as the rockers go your good you already have the 1.6 rockers on your car. If do get anything get the hardened push rods and new rollers. and that will give you everthing from valves to cam and you'll be straight. Drop me a line if you need anything
PostPosted: Fri Oct 26, 2001 7:59 pm
As far as I know, bigger is not better when it comes to the CC on heads. The bigger the CC, the less compression you get. You'll have to figure out what size CC will give you what compression ratio with the pistons you have. You don't want to go to high, of course. Unless you want to buy racing fuel all the time.
 Post subject: Thats a Roger
PostPosted: Fri Oct 26, 2001 8:45 pm
Chevythunder you hit the nail dead center on that one. Mike thats a true statement on the heads, you want to make sure your car can handle the port i've been talking to quit a few people in the states and I always get the same answer. If you go with the stage 2 port you should be fine the stage 3 is a whole different story it's not streetable. I'm talking about the LT4 from AFR the ones we were looking at in GMHT.
 Post subject: Thanks guys...
PostPosted: Sat Oct 27, 2001 11:24 pm
I am definitely buying new ones and selling the old. I want to start fresh. Thanks for the inputs. Ryan, hardened push rods? They were the cheapest ones one thunderracing.com. Are they the best? And you said rollers? What kind? One more thing, AS&M sells a 58mm throttle body and an even bigger monoblade throttlebody. Does the monoblade require anything special to run it, it's huge. Just bigger headers or what? Thanks again guys, Mike
PostPosted: Thu Nov 08, 2001 4:43 pm
Sell the heads backto me Playa......
