It is currently Thu Mar 26, 2026 4:06 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: Clutch question
PostPosted: Sun Nov 04, 2001 4:26 pm
I think I am going to need a new clutch soon. I was trying to do a second gear burnout. Get the RPM up, dump the clutch and floor it. All I get is smoke from the clutch and go no where. It will hold doing it in first, but not second. Also I noticed if I get on it hard, at high RPM, I hear a whining noise that rises and falls with the sound of the RPM. So I think if I plan on doing much with it, I should replace the clutch sometime. Suggestions on a good clutch setup and price?
PostPosted: Sun Nov 04, 2001 4:58 pm
There are only 2 good clutch setups for the LS1s. One is made by Ram. Probably will run aroud $300.
The other is made by Cartek. Will run around $500-600ish.
The Cartek is by far the best clutch for our cars. If you can afford it I highly recommend it. Talk to Jack about his.
-- Jamey --
PostPosted: Sun Nov 04, 2001 6:09 pm
It's awesome Jesse. I also bought the billet steel flywheel from SLP, 'cause Cartek doesn't sell one with their setup. You will either have to buy a new one, or have yours resurfaced.. I highly recommend it. It's not cheap, but neither is going fast!! ;)
PostPosted: Sun Nov 04, 2001 7:02 pm
Is a new flywheel necessary? Especially I only really have 7500 miles on mine right now. I was also thinging about the aluminum flywheel. I probably won't do this for a couple months. Did you get the adjustable Master cylinder?
PostPosted: Sun Nov 04, 2001 7:06 pm
Yes, I got the complete set. It is like 860 bucks, but I got in on a GP, and paid 760!! As long as your flywheel is usable, it will work, but it is recommended to have it resurfaced..
PostPosted: Sun Nov 04, 2001 8:13 pm
You don't need a new flywheel. You can resurface the factory one twice and still be ok. whether its needed or not, I'm not convinced. Mine looked fine so we didn't resurface it. Haven't had a single problem and it gripps like a mofo. If you do get a new flywheel, don't go aluminum. I've heard it more than once, it is for racing.
PostPosted: Tue Nov 06, 2001 5:52 pm
Mine was really bad, I'm glad I got the new one!! Maybe I just shift too hard.. :-dunno:
PostPosted: Tue Nov 06, 2001 5:56 pm
Well since you have a LS1, blame it on the power. If you had an LT1 you could have blamed it on the shifting..:)
PostPosted: Tue Nov 06, 2001 5:58 pm
LOL, yeah, probably a bit of both.
PostPosted: Tue Nov 06, 2001 8:03 pm
Me too. I will probably wait till I get back to the states and then do the clutch. It should hold out a couple months. It's not fried YET. If it does go, I will take it in for warranty and have it done and then redo it in the states anyway. I will go with the same setup as you Jack. Keep me informed on how it does. Do you get the adjustable master with it?
PostPosted: Tue Nov 06, 2001 8:12 pm
What's that about? :-dunno:
PostPosted: Tue Nov 06, 2001 10:04 pm
It's a joke, Dave!! :p Jesse, you can buy it with slave and master, or just clutch. It's up to you.. With everything, it's about $860..
PostPosted: Wed Nov 07, 2001 1:12 am
Is that with the flywheel? Cartech is advertising $630 for the clutch, pressurer plate, master and hydraulics with the master core.
PostPosted: Wed Nov 07, 2001 1:15 am
no flywheel, that was with everything else though...
PostPosted: Wed Nov 07, 2001 7:08 am
I know, I was just playin along. :P
PostPosted: Wed Nov 07, 2001 12:48 pm
No joking on my threads, this is serious business!!! j/k
PostPosted: Wed Nov 21, 2001 1:18 pm
Stop doing 2nd gear high reving burnouts but it is prolly too late to save the clutch 2-3 clutch smokies and it will be glazed. You might get it replaced under warranty?
PostPosted: Wed Nov 21, 2001 6:39 pm
Silly question , but what possess you to dothat in second gear instead of first? if the clutch did'nt slip you would of more than likely got nothing more than a chirp un less ythe back wheels were standing in water.
PostPosted: Wed Nov 21, 2001 6:43 pm
I was told that's what you do. Rev it, dump in second. First is no problem.
PostPosted: Wed Nov 21, 2001 6:46 pm
I think you could grenade the POSI. So when you get a new high speed clutch remember it prolly will not slip and you will break the weakest link.
