It is currently Wed Mar 25, 2026 11:07 pm
 Post subject: blew my 2nd belt
PostPosted: Mon Nov 26, 2001 7:50 pm
I guess it happens to LS1's above 6500rpm it creeps off the front and shreds so I pack a spare. Just try to find one when you need it. Pretty hard but can be done. It does not happen to the short belt for the AC
PostPosted: Mon Nov 26, 2001 8:10 pm
Is it blowing off of the crank pulley or one of the accesory pullies?
PostPosted: Mon Nov 26, 2001 8:14 pm
Belt tensioner pulley is the problem. I am wanting to jam it tight but kinda like the quick change short belt game.
PostPosted: Mon Nov 26, 2001 8:16 pm
Jam it, then all you have to do is take the center bolt out of the pulley... Will that work?
PostPosted: Mon Nov 26, 2001 8:25 pm
No because the short belt for racing is tighter and that is how I bought it. I will be buying a very tight normal belt to hopefully cure this problem actually I had a hard time getting it on I will let you know if it works?
PostPosted: Mon Nov 26, 2001 8:41 pm
Cartek has a tensioner for around 100 bux that will solve that problem...it solved mine ;)
-- Jamey --
PostPosted: Tue Nov 27, 2001 3:16 am
Oops, make that Katech!!!
Katech...Cartek, what's the difference???
-- Jamey --
PostPosted: Tue Nov 27, 2001 11:22 am
Jamey you had the problem also? How tight should I be running the belt for 6900 RPM's? thanks.
PostPosted: Tue Nov 27, 2001 12:17 pm
What the hell are you doing running that high up? Your bottom end isn't gonna take that abuse much longer. 6 bolt main or not.
PostPosted: Tue Nov 27, 2001 1:58 pm
Right now it only spins 6600RPMS REV limit but I will be pushing further next year Rev limit set @ 7000 I am updating the rod & main bolts. I will be staying with the 346 CI until she blows. Then it will get the Z06 short block LS6.
PostPosted: Tue Nov 27, 2001 4:29 pm
Ah so.............what you doin a 355-360 this winter?
PostPosted: Tue Nov 27, 2001 5:35 pm
No boring or stroking for me until my warranty runs out. But I do plan to upgrade to 2002 LS6 spec short block this winter. This is still in the planning stage and I am still waiting on some answers about pistons, gaskets and crank. and if I could upgrade the LS1 block to a LS6 this upgrade should be out real soon.
PostPosted: Wed Dec 05, 2001 12:23 pm
Dang Bruce you're insane!
PostPosted: Thu Dec 06, 2001 6:11 pm
I am doing a couple other things on the top side but she should spin 7000 easy and I will be feeding the monster with #36 injectors it will still be a 346. You will see in the spring!!!
