It is currently Sat Oct 17, 2026 7:54 am
Post new topic Reply to topic  [ 123 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Mon Dec 03, 2001 4:51 pm
It wouldn't have mattered on that race. I forgot I had ASR on and it automatically forces the throttle back. That's why I am thinking I may need the reversal switch.
PostPosted: Mon Dec 03, 2001 7:36 pm
Found the Spec stage 3 on Fast Toys for $528. Has anyone ordered from them before? If they are good I will order it from them.
PostPosted: Mon Dec 03, 2001 7:47 pm
Do a search on cz28 or ls1.com, I have not ordered from them, but I have not heard bad.
PostPosted: Mon Dec 03, 2001 7:48 pm
Do a search on cz28 or ls1.com, I have not ordered from them, but I have not heard bad. If you need help on the install, drive to K-town I am a pro on them now....
PostPosted: Mon Dec 03, 2001 7:54 pm
Then I will probably order it from them tomorrow. I e-mailed them today with a question I will see if they respond tomorrow or not and go from there. Thanx
PostPosted: Mon Dec 03, 2001 9:10 pm
They are based outta Canada and the last time I tried having something ship from them cost an arm and 2 legz. Maybe it's changed since then but look into 1st.\\
Nice races by the way!
PostPosted: Mon Dec 03, 2001 10:24 pm
Thanks John.
You still need a piece of aluminum? Get me an approx size and I will see what I can do.
PostPosted: Tue Dec 04, 2001 9:02 am
Well they e-mailed me back. They said they recommend the stage 3 kevlar clutch for what I have planned in the future. They also said that the clutches ship directly from STAR so they are checking if they will ship to an APO. I will find out tomorrow. Hopefully be able to order it before the weekend. Wonder if it will be here by the x-mas week off. That would be a good time to put it in.
On a side note the guy I am dealing with said he also has a camaro. He has a LS1 and a 6 psi PowerDyne SC on it. He said he ran 12.8 before the SC, but he hasn't made it back to the track since he put the SC on it. He told me he is running the stage 3 kevlar himself and is very happy with it. Of course he get's paid to say that though.
PostPosted: Tue Dec 04, 2001 9:09 am
Hopefully it will be here by then!
PostPosted: Tue Dec 04, 2001 9:13 am
yeah, but I somehow doubt it will make it. I should have my plugs by hten and I will intall them and mess around with the exhaust then also. I pulled the MAF screen out last night. So that's one less thing to get done. So much to do so little time and money.
PostPosted: Tue Dec 04, 2001 9:50 am
So you are installing plugs also? Remember side step a stage 3 clutch with traction and you could have more expensive problems.
PostPosted: Tue Dec 04, 2001 9:52 am
Yeah, I would guess the plugs are the original ones that came with the car, so I figure they could use a changing.
Expensive sucks. Is the rear end weak?
PostPosted: Tue Dec 04, 2001 10:05 am
I just did plug too. What a coinsidence! TR6's
PostPosted: Tue Dec 04, 2001 10:11 am
Krazy it is if you have traction and a stage 3 clutch.
PostPosted: Tue Dec 04, 2001 10:32 am
Krazy,
Where did you order your plugs from? I have to order some! I want to get some Nice NGK's or somthing like that!
PostPosted: Tue Dec 04, 2001 10:59 am
Plugs do very little for performance unless you are sniffing crack then cooler is better they prevents detonation and the need for a new engine!!!
PostPosted: Tue Dec 04, 2001 11:06 am
If you keep your stock gears, throw a TA Girdle with stud kit on your car you should be fine. There are plenty people running 1.5 60fts on stock 10 bolts....... Just strengthen what you have. Keep the stock gears as they are thicker..
PostPosted: Tue Dec 04, 2001 11:32 am
Scott, you can have my old TR55's.
PostPosted: Tue Dec 04, 2001 11:52 am
OK.....
PostPosted: Tue Dec 04, 2001 12:40 pm
I ordered them from AutoZone actually. Over the web. Only place I could find them for a good price. I found NGK at another place, but they wanted $9.80 per plug. No thanx. Like Hawk said as long as the plugs are working good then new plugs or different aren't going to help anything. Unless you are running nitrous or boost and then you want to run copper and 1-2 steps colder to prevent detenation. Do not run that platinum crap with boost or nitrous, they detenate a lot easier.
