It is currently Mon Aug 24, 2026 2:54 pm
 Post subject: Where to get Sub Frame Connectors installed at in Germany
PostPosted: Mon Apr 15, 2002 11:14 pm
Hello Everyone, I was wondering if you are aware of anywhere around the Vilseck-Grafenwoehr area or anywhere close by that can do the Sub Frame connector welding installation for me.
Any Help would be appreciated since I am not a car expert!
Happy Motoring
1995 TA
PostPosted: Tue Apr 16, 2002 5:09 am
I can weld them in for you. I live @ Rose Barracks and we can do it in the craft shop.
PostPosted: Tue Apr 16, 2002 5:14 am
Bruce
You wanna do mine also ?
PostPosted: Tue Apr 16, 2002 5:19 am
Sure if you are willing to drive to Vilseck on Friday we could go to N/burg. I have a extra bed and we could go to the craft shop Sat morning let me know.
PostPosted: Tue Apr 16, 2002 5:36 am
Bruce
Won't be able to make it right now but in the future if possible? Plus I wanna check out the feasibility of a 9inch for autocrossing /trackracing since you have one already
 Post subject: where to get sub frame connector installed?
PostPosted: Tue Apr 16, 2002 6:45 am
Thanks a bunch Hawk, I appreciate the help. I won't be able to do it this week since I wanted to figure out where to get it done first. I will go ahead and order it this week from BMR and will let you know when I get them. Hopefully you will have some time in the future to help this novice out.
Happy Motoring
1995 TA
PostPosted: Tue Apr 16, 2002 8:18 am
what car are you driving and where do you work?
Roy this setup seems to help the balance of the car. I should have the ABS solved VIA computer program. I will let you know The ABS still works in the front.
PostPosted: Wed Apr 17, 2002 10:27 am
Hawk, I am in 2/2 IN and I drive that silver trans am t tops that you saw about a month ago but with Blue Stripes now.
You can't miss me.
Hey Hawk I was looking at 17 x 11's in the back of my car zr1 type wheels. will these work without major problems.
Thanks in advance
Happy Motoring
1995 TA
PostPosted: Wed Apr 17, 2002 11:05 am
yes they will work minor modification required. I used to own the 98 silver Z-28 with 17x11 Forgelines that is up in your area.
PostPosted: Fri May 10, 2002 2:00 pm
mrchase1 some require rolling the inner fender well some don't. They'll look killer that's sure.
Roy from other's that autoX and what not the preferred rear is the 12. Too heavy is the main reason behind it and having to use solid mounts. Unless it's a wkend brawler only I'd go 12 bolt instead. Who's to say though. It's all a matter of preference I suppose.
PostPosted: Fri May 10, 2002 9:25 pm
Hummmm so lemmie get this straight.....If I lose a grudge to Bruce aka "Hawk" He would be beating me with some help from Ford Motor Co. ???? Is this correct??
SVT Slobra
PostPosted: Fri May 10, 2002 10:13 pm
Kinda I have a FORD rear but it is powered by GM.
