It is currently Sat Jun 27, 2026 5:36 pm
 Post subject: RAM VDS Clutch
PostPosted: Thu Jun 06, 2002 12:29 pm
IF you plan to upgrade the LS1 clutch this thing ROCKS. I have tested this thing without mercy it does not slip.
Test Included but not limited to
Side steping @ 5000
getting a squak in 4th @ 110 MPH
100's of WOT shifts
PostPosted: Fri Jun 07, 2002 3:47 pm
How much does it cost and can I use it with my stock hyd slave cylinder. Any mods to make it work?
Val
PostPosted: Fri Jun 07, 2002 3:55 pm
I have a drilled out slave fron last year. Yes it worked however the Mccloud slave is better. I actually have to use some force to push the clutch. Get with me before you buy.
PostPosted: Sat Jun 08, 2002 12:01 pm
Hawk
I've got the improved clutch set up (zo6 clutch,slave)that came factory on 2001 & 2002, that was supposed to fix the slave problems. I'm sure you know better than I so I'll get with you.
Val
PostPosted: Sat Jun 08, 2002 4:30 pm
I have an '01 with the Z06 clutch and slave. I did the drill mod, it helped, but the Z06 clutch started to slip a bit at 10,000 miles. Not that impressed with it.
PostPosted: Sun Jun 09, 2002 5:12 am
I just turned 13,000 on the Firechicken and I'm begining to wonder if mine is starting to slip. Sounds like I'll have to do that mod and clutch at X-mas. Thanks
Val
PostPosted: Sun Jun 09, 2002 7:39 am
There is no comparision between the two the RAM VDS doesnt slip.
