It is currently Sat Jun 27, 2026 10:13 am
 Post subject: Ala Coilovers & Upper & Lower BMR A-arms, New Bilsteins.
PostPosted: Mon Sep 02, 2002 2:47 pm
Looks sweet I might add too. Wasn't too bad of a install except for the lower spherical rod end. PITA. Aligment was pretty easy too. Car was too low initially so I took it easy on the way home so as not to damage the new revalved Bilsteins. I jacked it up today and will do another alignment later after inspection. Negative camber is so sweet! Well here's a shot I hope it shows up.
Screw it tired of trying.
The "SRZ"
PostPosted: Mon Sep 02, 2002 8:23 pm
Hm lets see whats up with the suspension.
PostPosted: Tue Sep 03, 2002 12:14 pm
Wow, tubular a-arms.. I'm impressed.. ;) Looks tigh John.
PostPosted: Tue Sep 03, 2002 2:24 pm
Me likes too. The rears are something to be desired however. Trying to figure out why I have the clunk action going on over bumps. Aside from that it's great.
PostPosted: Wed Sep 04, 2002 9:12 am
I bet it's stiff as all hell..
PostPosted: Wed Sep 04, 2002 12:03 pm
Please give me the full run down of the suspension mods front and back.
Have you done SFC's and STB?
Apart from weight, what other advanatge are the BMR A arms?
PostPosted: Wed Sep 04, 2002 3:07 pm
Actually Jack it's no stiff than yours. If you ever rode in Roy's car it's setup exactly like his to a point.
Jagsy. Suspension wise you can look in the member section and see my list. Too long to write but to be honest the whole thing has been redone no stone unturned. EXCEPT the rearend hasn't been touched. 12 bolt next yr for sure.
Weight wise it's the same if you ask me. I kept the stamped units just in case cause ya never know. Main advantage to these are the extreme camber I can now dial in if I want.
