It is currently Wed Aug 26, 2026 3:50 pm
 Post subject: Power gains for a 3.4?
PostPosted: Wed Sep 11, 2002 10:47 am
I'm posting this for a friend with a 3.4 who is planning on fitting a cold-air induction kit and a bigger exhaust. He was hoping for a 30bhp gain but I said that was going to be a little optimistic. Anybody know the likely gains. I reckon 15-20 maximum.
PostPosted: Wed Sep 11, 2002 11:34 am
I am thinking 5hp here. It would be more if it was pressurized from the chin spoiler.
Sergio what do you think.
PostPosted: Sun Sep 15, 2002 2:38 pm
 ICQ  YIM  Profile
If he is going with a complete exhaust replace, and the cold air, maybe, just maybe 15. But I think that Sergio is the man in this subject. I think that K&N was saying that their cold air kit makes like 11-12 but I don't believe 'em.
RT1 - Image
PostPosted: Sun Sep 15, 2002 4:52 pm
rule if thumb the closer to the valves the more Hapees you make. My guess would be around 5 also.
PostPosted: Sun Sep 15, 2002 4:59 pm
 ICQ  YIM  Profile
5?... really? Even with the exhaust? Can a brotha get a 10?
RT1 - Image
PostPosted: Sun Sep 15, 2002 5:31 pm
cat back exhaust is along way from the valves. LT Headers would make more & Cam would make even more because it opens the valves more/longer and the best is port and polish with bigger valves and a cam.
PostPosted: Sun Sep 15, 2002 7:30 pm
I agree with the porting/polishing. But you also have to include compression ratio in the mix also. To get the most out of the cam you also need the correct ratio. I told rt that I would not go any higher than 10.0-1. He would also need a wide lobe seperation so that he does not lose any vacuum which leads to other problems. Just my 2 cents.
Best 1/4: 13.587 @100.90mph
PostPosted: Sun Sep 15, 2002 8:32 pm
10.1 is good for his setup. CR is very important if you have all the other stuff and 8.5 CR it will not help very much
