It is currently Sat Sep 12, 2026 10:19 pm
 Post subject: Rocker arms!!
PostPosted: Tue Nov 05, 2002 12:18 pm
I'll be doing a rocker arm job this winter and would like to see if I can go higher than a 1.6 ratio. I did the math and a 1.7 lift would give me .544 intake/.589 exhaust. I can go as high as .600 on the LT1 head.
So my question is, has anyone ever done this or know if this will work? I think that the 1.7 rockers might fit from the LS1 heads but i am not sure.
Thanks
PostPosted: Tue Nov 05, 2002 2:24 pm
It highly isn't recommendend and as a matter of fact NO ONE does. The most I've seen is 1.65 and that's pushing. If it were to be done it needs to be done by a professional w/ the correct cam, springs, etc. If you look here someone else has asked about it as well......
http://web.camaross.com/forums/showthread.php?s=&threadid=43554&highlight=1.7+rr
PostPosted: Tue Nov 05, 2002 3:36 pm
Thanks John. That helps out alot. I will just buy the 1.6 and eliminate the worries.
PostPosted: Tue Nov 05, 2002 3:38 pm
howie can you look at my tranny post below urs and tell me if that will work.
13.022 @ 105.14
1.869 60'
PostPosted: Tue Nov 05, 2002 5:23 pm
Did you get your car running yet?
PostPosted: Wed Nov 06, 2002 1:48 pm
mine is still sitting at the hobby shop. Havent had time to do anything yet to the rearend but I have all winter so I am in no hurry really.
PostPosted: Wed Nov 06, 2002 2:15 pm
Hey Badazz',
It all sounds good to me. I think you should put that $100 towards a custom program though. I got mine programmed for $150 and it was the BEST $$$ i have spent. You can have the rev limiter changed to whatever you want and then some. Just my 0.02.
 Post subject: Re: Rocker arms!!
PostPosted: Sat Jan 11, 2003 10:16 pm
Thanks
Log onto the "LT1 Tech" message forum at http://www.camaroz28.com and do a search for "Sar2k"....... He has an LT1 with adjustable roller rockers. I'm not sure what ratio he is running though. If you can't find what you want, sign up and private message him, he is a very nice guy and has helped me out before......
John
1995 Camaro Z/28 auto
K&N intake, 1LE intake elbow, TB airfoil, Meziere electric waterpump, SLP headers, Flowmaster catback, 1LE driveshaft.
AIM Fastzntn
