It is currently Sat Sep 12, 2026 4:00 pm
 Post subject: Jiffy Pop Sound from the Exhaust!?!?!?!?
PostPosted: Sat Feb 08, 2003 10:12 pm
I have had this sound for a while and am finally just sick of it. After I get on the gas if I let off it sounds like the car is back fireing (and let me tell you somthing nothing impresses people more than a car that backfires!). I scanned the car with my Snap-On scanner and found no codes..... but when I checked the data flow stream I found some funny numbers...... my MAP (manifold absolute pressure) is supposed to be from 3V to 5V and I only have 1.31V? I checked the intake for leaks (did the ol WD-40 test... the engine is suppose to rev up if the WD is sucked in by a vaccum leak) and nothing happened? What I am wondering if this noise is supposed to be a normal thing or somthing I should be worried about..... also if there is anything else that could be causing it. I was also told to change my cat's over to free-flow's to lower the back pressure in order to stop the noise..... Any suggestions would be appreciated! Thanks all!
PostPosted: Sat Feb 08, 2003 10:25 pm
My car backfires some times too.....
sure its not vibrating on a cross member?
does it sound like this? http://us.f1.yahoofs.com/msgr/steven_ma ... _DlbtiK1cq
.....just kidding but click it anyway my car with its new open headers :) :twisted:
13.022 @ 105.14
1.869 60'
PostPosted: Sun Feb 09, 2003 12:32 am
Jr
If you are not losing any power I wouldn't worry to much about it. Mine does it all the time.
All that is basically happening is the unburned fuel and gases are combusting in the exhaust.
PostPosted: Sun Feb 09, 2003 1:23 pm
Mine pops like crackling on the over-run.
