It is currently Mon Aug 24, 2026 10:47 pm
Post new topic Reply to topic  [ 140 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Mon Dec 15, 2003 4:19 pm
That would easily pay for the machine, or? The possibilities for that thing are truly endless..
PostPosted: Mon Dec 15, 2003 4:30 pm
Only problem is, the machine is built for home use no doubt - don't know what speed it has, but I do know it only has one thread - so multiple color embroideries require multiple thread changes ... don't know what amount of load it will allow before breaking something ... ("Can I bore this .030 over?" :lol:)
PostPosted: Mon Dec 15, 2003 7:40 pm
If you get into it big enough, there is some money in it. I knew a guy in Louisiana who had 20 machines with 20 heads each. It took 20 employees just to run them. He was into it big time.
PostPosted: Mon Dec 15, 2003 7:55 pm
Well, I know they charge an awful amount of money for decent embroidery patterns ... stupid cards with 10 patterns or so go for 150€ and more ... but after trying to get the FBE and 1on1 logos right, I do understand why ... takes quite a bit of planning and thinking ...
PostPosted: Tue Dec 16, 2003 11:27 am
If it makes you feel better, I'll buy a few shirts.
PostPosted: Tue Dec 16, 2003 11:52 am
Hopefully, I'll have a sample pic up by the weekend ...
PostPosted: Tue Dec 16, 2003 12:10 pm
Oh, I didn't know it was only 1 thread. That kind of sucks! :? Better than nothing, that's for sure!
PostPosted: Tue Dec 16, 2003 12:13 pm
There are some available with 4-8 different colors, but in the 4grand and up range ... guess once I have a backlog of 500 pieces, I'll go out and buy a bigger one ;)
PostPosted: Tue Dec 16, 2003 2:40 pm
sticker price:shock:
PostPosted: Tue Dec 16, 2003 3:10 pm
Yeah, but you could pump out stuff quick with those multi-colored machines. That could truly be a good business. Just buy boxes of t-shirts at a time, and do many of the same designs. Okay, enough of my personal opinions. I'm just thinking about what I would do!
PostPosted: Tue Dec 16, 2003 7:10 pm
Well, got my "Christmas present" today (finally) - guess I'll have some learning to do ;) anyway, preliminary info (based on machine calculation) states the FBE logo w/o the black background (that is, on a black or dark blue T-shirt) will take somewhere around 22 minutes, on a lighter background around 29 minutes - plus the time it takes to change the thread in between colors ...
Look out for a sample picture here soon ;)
PostPosted: Tue Dec 16, 2003 9:17 pm
I will take a few shirts as well! Like Jerry said, there is money to be made. Start thinking about next years Cars Are The Stars!!! 8)
PostPosted: Tue Dec 16, 2003 9:25 pm
Hm ... did the first run ... learned a couple things ...
  • I'm pretty quick changing threads already - but the machine makes it easy, just pull the threads a couple different directions, fiddle a bit at the needle, use the threader, done ... can be done in a minute ...
  • The program lies about a couple things in the preview ... for one, lines aren't as wide as the look ... ended up with some gaps at a couple places ... got to make sure I overlap some more there
  • The hint in the manual about putting some chalk mark in the middle of where you want to put the embroidery wasn't too bad - I didn't, and ended up with the logo a bit too far to the left ...
  • The font doesn't look to good yet, but that might be in part because:
  • the shirt has to be in the frame real good, and shoudn't pull too much ... oh well ...
  • The current size maxing out the available space in the frame might not be the best idea - the logo might even look better a bit smaller (like 2-3in). As it is now, it does look pretty good from 10ft away or so ...
All in all, I'm halfway satisfied for the first try ... the old shirt I used has pretty thin, soft material, so a decent shirt should end up better as the material doesn't stretch/pull as much during stitching. Also, from this first sample, I would say I will not be doing the logo on a light background - the way the filled area is stitched, building the black BG from thread will most likely look like a POS ... so, black or dark blue are the colors ...
PostPosted: Wed Dec 17, 2003 7:27 am
Care to post a pic of the first attempt?
PostPosted: Wed Dec 17, 2003 11:02 am
I can try to take a pic tonight or tomorrow ...
PostPosted: Fri Dec 19, 2003 1:45 pm
OK, got some prices ...
T-Shirts (from "B&C") will be about 19€. Heavy cotton, very good quality (from what I am told)
Pullover/Sweatshirt style will be about 29€, from Hanes.
Prices are with the embroidery, and at 20pcs each, so I will want to collect at least 10-12 orders before I get 'em ...
I will pick up samples next week and post a pic ...
Apart from the FBE-Logo, I could also do things like a Chevy logo, or 'vette, etc ...
Also, I will stick with the fonts built into the machine, as the TTF ones I tried were completely messed up ...
PostPosted: Fri Dec 19, 2003 4:02 pm
I'll take a dark gray T-shirt, size XL and a black long sleeve also size XL. The colors are just my preference if they are available. Thanx.
PostPosted: Fri Dec 19, 2003 4:51 pm
What colors are available, Garry?
PostPosted: Fri Dec 19, 2003 5:48 pm
As mentioned before, it will have to be dark colors, as stitching the black background isn't an option ... so, either black, dark blue, dark grey, etc. would be reasonable - need to check what's available ...
PostPosted: Fri Dec 19, 2003 6:36 pm
Cool, I think I'd take a T-Shirt and a sweatshirt... :)
