It is currently Tue Aug 25, 2026 8:45 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: Hey Bruce
PostPosted: Sun Mar 21, 2004 7:47 pm
what are your specs of your cam at .050. I can recall what yours sounded like. just wondering your specs
many mods,
PostPosted: Mon Mar 22, 2004 5:52 am
who is running a radical cam please post your specs i am curious
many mods,
PostPosted: Mon Mar 22, 2004 7:04 am
I think only Bruce , Nick , Jack and Silas are the only ones running anything on the rad side. THe First three I believe had basically the same type.
PostPosted: Mon Mar 22, 2004 7:49 am
I'd tell you, but I don't know where my spec sheet is.
PostPosted: Mon Mar 22, 2004 7:57 am
Jack thatsounds like top secret squirrell stuff.
But I thought you would say "if I tell ya I gota kill ya" :P
PostPosted: Mon Mar 22, 2004 8:23 am
It's basically the same thing, isn't it? :twisted:
Actually, it is a custom grind, so it should be rather confidential!
PostPosted: Mon Mar 22, 2004 8:34 am
Currently 224/228 581/588 Comp Cam
Will be 231/237 598/595 Lunati
PostPosted: Mon Mar 22, 2004 9:51 am
I run a .544/.560 110 LSA 232/242 duration. Will be swapping it next spring though for the likes of a 242/252 .590/.610 lift. :D
PostPosted: Mon Mar 22, 2004 10:50 am
MY CAM IN MY 393 IS A 260/276 CUSTOM I WAS JUST WONDERING . I THINK IT MAY BE TOO RADICAL. I KNOW I WILL NEED A VACUUM CAN. BUT I AM REALLY CONSIDERING DOWN SIZING.
many mods,
PostPosted: Mon Mar 22, 2004 10:53 am
THE ONE I IN MIND IS 244/256 WITH A 656/664 LIFT ON 114 LS
many mods,
PostPosted: Mon Mar 22, 2004 11:58 am
Damn John, I need to hear your car again? How long has that cam been in? That can't be the same one you had in there last year. :shock:
PostPosted: Tue Mar 23, 2004 4:06 pm
It's the same cam Jack. Some days it sounds bad azz and other days docile. :D Depends if I got the exhaust fully opened or not. Oh but it I throw the superchip in that thing sounds like NASCAR. Don't know why but that chip makes that car sound and run totally different then Ed's chip. Now I just got PCM4less chip last wk my wife said. So I'll try that one once I get back and see what it does.
PostPosted: Tue Mar 23, 2004 7:40 pm
wait till you get state side john then you can get a dyno tune and know you got every bit of power out of itwith a safe fuel ratio.
many mods,
PostPosted: Tue Mar 23, 2004 7:43 pm
You are absolutely right w/ that. The cam was free though but I'll probably still wait. I do know once I get back I'll have it redyno'd at the VW shop or Nurnburgring w/ all 4 different chips and see which ones the best overall.
PostPosted: Wed Mar 24, 2004 2:18 am
YOU REMEMBER WHEN WE DYNOED YOU AT THE VW SHOP. THOSE GUYS TRIED TELL ING US THAT BHP WAS BRITISH HORSE POWER. IT MEANS BRAKE HORSE POWER AND IT MEANS AT THE WHEELS. YOU MADE 425 HORSES AT THE WHEELS THAT DAY AND THAT WAS SHUTTING DOWN EARLY.
many mods,
PostPosted: Wed Mar 24, 2004 4:18 am
Would you like to correct this statement ?
PostPosted: Wed Mar 24, 2004 5:22 am
AM I WRONG IF SO THEN PLEASE CORRECT ME /. THIS IS WHAT I WAS TOLD.
many mods,
PostPosted: Wed Mar 24, 2004 6:01 am
Well, the guys at "Top Gear" keep using that phrase, too ...
Googled it, here's one of the things I got:
"A unit of power, used in stating the power required to drive machinery, and in estimating the capabilities of animals or steam engines and other prime movers for doing work. It is the power required for the performance of work at the rate of 33,000 English units of work per minute; hence, it is the power that must be exerted in lifting 33,000 pounds at the rate of one foot per minute, or 550 pounds at the rate of one foot per second, or 55 pounds at the rate of ten feet per second, etc.
Brake horse power, the net effective power of a prime mover, as a steam engine, water wheel, etc., in horse powers, as shown by a friction brake. See Friction brake, under Friction.
Indicated horse power, the power exerted in the cylinder of an engine, stated in horse powers, estimated from the diameter and speed of the piston, and the mean effective pressure upon it as shown by an indicator. See Indicator."
So, BHP (if I understand it correclty) is the power at the wheels (as used in German HP ratings), while "IHP" would be the HP rating used in the US ...
PostPosted: Wed Mar 24, 2004 6:07 am
SO WHAT IS THE DIFFERENCE IN BHP AND U.S. HP
many mods,
PostPosted: Wed Mar 24, 2004 1:04 pm
I believe the US goes by flywheel and EU go by rearwheel. I wish I could get clarification on that.
Users browsing this forum: No registered users and 12 guests
