It is currently Mon Sep 21, 2026 9:42 pm
 Post subject: Fans coming on @ 175 degrees
PostPosted: Tue May 11, 2004 5:58 am
Has anyone ever had the problem of the SES lighting up then kicking on the high speed fans? I know the fan sensor is located on the water pump housing on the LT1. Could this be the culprit? I had the codes scanned it it came up with a code 29- Secondary Air pump inop and a code 42- Ignition problem. I don't see where any of these codes would cause the fan to come on. It really drains my battery and causes the car to run a little rough. Any help would be GREATLY appreciated.
PostPosted: Tue May 11, 2004 7:14 am
dont know for sure but check the under hood relays.
PostPosted: Tue May 11, 2004 8:03 am
I had to replace my air pump due to this. No big deal.
PostPosted: Tue May 11, 2004 12:26 pm
Even when I remove the fan relays the computer overrides them and turns the fans on. My car does not have an air pump because I removed it when I installed the long tube headers. The air pump will cause the computer to kick on the fans?
PostPosted: Wed May 12, 2004 7:22 am
That could be possible.
PostPosted: Wed May 12, 2004 7:46 am
My fans came on all the time (sometimes with a SES) or just sometimes when my coolant temp sensor was loose / broken...
Its some kind of emergency procedure to prevent the engine from overheating because the pcm doesn´t know the coolant temperature.
PostPosted: Wed May 12, 2004 10:09 am
Anything is possible. A taillight bulb that has been removed will set off your airbag light. :?
 Post subject: I know that!
PostPosted: Wed May 12, 2004 11:17 am
Same problem here...
My car always blows that 20 Amp Air Pump fuse and then the SES light comes on when driving and the hairdryer starts up.
Funny thing is: Only when driving.
As soon as i stop on a stoplight, after about two seconds SES goes off and after about 10 seconds of idling the fans stop. Funny thing.
Goes i have bad air pump? Didn´t even know i need sumthing like this :)
R@M
Got boost?
PostPosted: Fri May 14, 2004 5:56 am
Rampage,
I have an air pump sitting in my basement. I do not need it now. I would give it to you. I actually fixed mine the other day. I just put the air pump relay back in and hooked up the EGR Valve. Problem solved. Goes back to my old saying that I seem to never follow "Leave well enough alone!"
 Post subject: Sure!
PostPosted: Fri May 14, 2004 9:08 am
Sure! Would help a lot!
Any other parts you want to sell by chance??
I am starting to look at a complete rebuild, as the more i look into the car the more parts needful of replacement i find ;(
R@M
Got boost?
PostPosted: Fri May 14, 2004 9:31 am
Hey Rampage, you have no cat - so why do you need a air pump? :lol:
 Post subject: Cat...
PostPosted: Fri May 14, 2004 10:02 am
For the darn fans to stay off. Or any way to bypass it :)
Also you are wrong. I do have a cat. She´s 5 years and black and white, maybe she´ll need it.
J/K, i guess i´ll return some things to stock, especially if i want the car to be registered normally someday in the far future...
R@M
Got boost?
PostPosted: Fri May 14, 2004 10:20 am
Blowing up your cat (to double size or whatever) is for sure against the law :lol:
PostPosted: Fri May 14, 2004 10:51 am
Actually she´s asthmatic, so already heavy breathing...
Wanted to give her some performance intake, too!
Got boost?
