It is currently Sun May 03, 2026 8:56 pm
 Post subject: Dyno Numbers 2
PostPosted: Wed May 12, 2004 9:03 am
today i was at the dyno, here are the numbers:
248,5 KW 5270 R/PM
485 NM 4680 R/PM
I´m glad with this numbers, but what i want to ask you is: My engine stopped at 5430 R/PM. Does your LS1 do the same?
PostPosted: Wed May 12, 2004 9:11 am
Governor kicking in? What speed was the tach showing?
PostPosted: Wed May 12, 2004 9:24 am
the Speed on the monitor showed: 260 KM/H at 5430 R/PM. Than it stopped from the engine.
PostPosted: Wed May 12, 2004 9:27 am
Sounds like the speed governor to me ... lucky you, mine cuts off at 197k ... :(
PostPosted: Wed May 12, 2004 9:40 am
My car does the same thing in 5th gear, so I guess it's something like a speed limiter. Rev limiter is set at 6000 (?) I think...
PostPosted: Wed May 12, 2004 9:47 am
That means, our camaros are running 260 KM/H and not faster? Can i do something about it?
PostPosted: Wed May 12, 2004 10:17 am
My car shut off at 170mph, didn't know at the time, scared the hell out of me when it did. Just reprogram the computer. Hypertech makes one along with others... TuV won't know either. :wink:
PostPosted: Wed May 12, 2004 11:04 am
Get a Predator Programmer. It is about $50 more than the Hypertech but you can actually adjust your timing and fuel curves with it. You will also be able to take out the governor. You can order one from T-Byrne.
PostPosted: Wed May 12, 2004 12:55 pm
how much cost a predator programmer? ow much more Horsepower will i get? Is it ok for the engine or making trouble?
Who knows more about this predator programmer?
PostPosted: Wed May 12, 2004 3:28 pm
I have mine set at 255 MPH cost is in the $300--350 range.
PostPosted: Wed May 12, 2004 3:41 pm
332 hp at the wheels not. Bad! Will be higher had it not shut off. I don't know the torque conversion though.
PostPosted: Wed May 12, 2004 4:37 pm
248,5 KW = 339 HP at the engine. On the weels it was 262 HP.
Is a predator programmer only for one car, like the hypertech programmer?
Hawk i saw your firehawk in bitburg, wow :shock:
PostPosted: Thu May 13, 2004 7:52 pm
JENS
I have the Predator and it works GREAT. Very user friendly and they claim a 10-20hp increase by using their "sport tune" right out of the box. It shouldn't create any problems for you but rather help you to solve them is something goes wrong with the car. I noticed a difference with my car when I used it, very nice machine. I still need to change the rev limiter and top speed....will do that after the cam change :D I would buy the predator over the Hypertech anyday!
PostPosted: Fri May 14, 2004 8:55 am
According to my 4th gen road test book, the LS1 is governed to 158mph.
PostPosted: Fri May 14, 2004 10:28 am
My friend in Hanua just bought a Predator Programmer for his 2002 Camaro SS. He is bringing it down this weekend so I can install his exhaust. I will check out the programmer. If you buy the Predator make sure you get the 160 degree thermostat or you could run into detonation problems when you go to the sport tune. The Predator costs $410 and it is for one car only.
PostPosted: Fri May 14, 2004 12:49 pm
Ok, thank you. I don´t have the money for the programmer yet. At first i must buy new suspension parts, my suspension is terrible for this engine. But i must wait a few month, till i have enough money for buying parts.
Jens
PostPosted: Fri May 14, 2004 2:38 pm
You put the 1LE from the 'bird on or what? Or are you still driving with your V6 sway bars??? Better not ... :) :evil:
PostPosted: Fri May 14, 2004 3:08 pm
Jens,
I have a front sway bar, front springs, rear springs, rear control arms, and panhard bar from a 2002 Camaro SS. The front sway bar is huge compared to the one off my 95 Z28. Are you interested?
