It is currently Mon Aug 24, 2026 11:08 am
 Post subject: Best Crate Engine for the F-Body
PostPosted: Wed Jun 23, 2004 2:28 pm
In your opinion what is the best Crate Engine to buy for the 98-02 F-body that is under $10,000.00 and is street legal???
PostPosted: Wed Jun 23, 2004 5:14 pm
Here is what you need my friend! ;) http://www.cartek.net For a couple thousand more though, you can have a 422. ;) That's big power, but so is the 383. ;)
CARTEK BIG BORE 383 CID LS1 LONG BLOCK
Cartek custom heat treated crankshaft
Scat 4340 connecting rods
JE custom forged pistons
Plasma moly rings set
Clevite P series race bearings
Rotating assembly fully balanced
Engine blueprinted
Cartek hyd. roller cam
Double roller adjustable timing chain
Cartek stage 4 LS1 heads
Fully assembled long block (engine block and head core required)
$10,250.00
PostPosted: Wed Jun 23, 2004 5:15 pm
If you do that though, you will, and I repeat WILL need a new rearend. Hell- if you do heads you'll need a new rear. If you have the money, buy it all at once, but if not, build up the drivetrain first, to save yourself some headaches and money! ;)
PostPosted: Wed Jun 23, 2004 6:24 pm
You can make a 600 hapee street monster out the of the one you got for about 1/2 that these days I got a couple connections. go witha a setup like mine and apply my lessons learned and you will save big time.
PostPosted: Wed Jun 23, 2004 7:36 pm
I was gonna say that, but I thought if you have the money, you should go all out.
PostPosted: Thu Jun 24, 2004 5:47 am
For 10 large, you can buy a new Ford 9" rearend ($3000), a heads/cam setup ($2000), a set of forged pistons ($600), a set of billet connecting rods ($1200), a new driveshaft ($350), and whatever else you might need- with money left over! ;) You have so many options Hoch, so check LS1Tech, visit some of the vendors, and find out what you think you'd want. You should have no doubt by the time you are done with your research. For that much money, you can be in the 10s for sure! ;) You also might want to look at a serious brake upgrade too, while you're at it.
 Post subject: Breaks
PostPosted: Thu Jun 24, 2004 3:13 pm
Breaks? Hell I won't need any breaks.... wings maybe. :)
 Post subject: LS1
PostPosted: Thu Jun 24, 2004 3:15 pm
I just seen an articel of an LS1 that has 1200 HP and does 8.5... oh... and the Trans Am was a convertable too...
PostPosted: Thu Jun 24, 2004 3:20 pm
:crazy:
Until November 2004 I had a:
PostPosted: Thu Jun 24, 2004 4:06 pm
Yeah I have that edition of GMHTP. That thing is wicked.
PostPosted: Thu Jun 24, 2004 7:38 pm
since you don't work on your car yourself, take one third ($3333) to put in the upgrades, another third ($3333) for the mechanics to do the job.
the third part? $3333 you need for the fixes of the upgrade later on.
sorry for my sarcasm. just some realistic numbers here, guys. :roll:
PostPosted: Thu Jun 24, 2004 7:53 pm
You're preaching to the choir Silke! :cry:
PostPosted: Thu Jun 24, 2004 7:58 pm
To tell the truth, you're just talking about Jack
PostPosted: Thu Jun 24, 2004 8:00 pm
Daddy, you better be quiet for a while.
PostPosted: Thu Jun 24, 2004 8:21 pm
What the hell did I do this time?
PostPosted: Thu Jun 24, 2004 8:25 pm
you don't want me to say.
Call me and tell me then
 Post subject: LS6
PostPosted: Fri Jun 25, 2004 5:26 am
I was not going to upgrade my engine until the warranty expires. Then I started thinking. If I am going to upgrade, and I have not started yet, why not get an LS6, and upgrade that instead of upgrading the LS1? Or even a better motor than the LS6.
Whatever I do, my end state is to have about 600 HP and run in high 10s to low 11s (without NOS). I would never do NOS. I would spend the money on TT or Supercharger before NOS.
PostPosted: Fri Jun 25, 2004 7:10 am
Hope you got a 2nd car. You are going to be breaking things left and right if you don't do it right. Beef up the tranny w/ Viper internals because if you don't you'll munch that thing in the 1st yr if not a little later. 600Hp isn't as easy as some make it out to be. You could have a 600HP head cam package but if there is no dyno tuning you out a 40-60hp easy.
Good luck in your quest.
PostPosted: Fri Jun 25, 2004 8:57 am
600 hapees without a power adder will be QUITE a feat. I think it might take a little more than 10 large. :)
