It is currently Tue May 05, 2026 6:04 am
 Post subject: Engin Swap
PostPosted: Tue Aug 07, 2001 10:43 am
I have a 91 RS. I swaped out my 305 for a 350 I havent done much with it yet but now I have a good deal on a LS 1 should I build up the 350 or swap out for the LS 1? I want to get at least 400hp. I just did a major install on the interior where I removed all the factory molding and plastic so the wood and fiberglass added about 200 lbs easy. So I want to build up the motor so I can have speed and sounds. Any advice you guy's have would be great.
PostPosted: Tue Aug 07, 2001 4:57 pm
You will need the wireing harness and computer. The best way is to have a donor car right there so you have everthing. It will get expensive if you buy one piece at a time. 500HP LS1 cost about $5000 so 400HP would be $2500 heads and medium cam. Best deal is 350HP with free mods. It is still expensive to pump up the LS1 because it is still kinda new. The LS1 has a wide powerband so it would be pretty good transplant.
PostPosted: Tue Aug 07, 2001 9:39 pm
I would use the money and build up the 350 you have. Im not saying the LS1 is bad at all, but the money would be streched out farther on mods for your current 350 and not on stuff to convert over to a LS1, if you know what I mean. I had the oppertunity to build up a LT1 or beef up my L98, and I went the way of the L98. Just my .02c though. See my sig for my mods, I spent about 3 G's
PostPosted: Wed Aug 08, 2001 6:29 am
what kind of HPs is the L98 pushing? will you be racing this weekend? were are you from? Gieb?
PostPosted: Wed Aug 08, 2001 8:33 am
The TPI 350 or L98 is pushing 245 hp and 345 ftlbs stock. You'll notice thats more torque than the LT1 and LS1 stock. Im not saying its faster just thats its a stump puller of a motor on torque. I built my enging with TPIS help to make my combo as best I could. They told me this combo is worth 400 hp and 390/400 ftlbs at the flywheel, and my goal was to have a 400 hp car. So Im just as interested to see what my car will do this weekend.
PostPosted: Wed Aug 08, 2001 8:41 am
Sounds like it should be quick do you have it dialed in.
Tony will be there to help us out. Are you from gieb? I think I remember you from wurzburg.
PostPosted: Thu Aug 09, 2001 2:58 pm
I have the computer and the wiring harness with the motor.The owner already upgraded the chip. Tony said I will have to change the fule system, but I am still up in the air on what will be the best for preformance and money.I will be at Bitburg on Sat with Dave he works with me so I hope to meet you guy's there. JAZ
PostPosted: Thu Aug 09, 2001 3:02 pm
Cool I will be there saturday. Tony will also be there sunday.
PostPosted: Sun Aug 12, 2001 6:15 pm
Hey sweeny I think I grabed your gas by mistake when we were leaving on Sun. I didnt think about it but when I put the rest of the big 5 gal in I noticed the color differance.If it was yours Im sorry I will give you the money for it. JAZ
PostPosted: Mon Aug 13, 2001 10:03 am
Thats funny, he was looking for it right after everybody left.
PostPosted: Mon Aug 13, 2001 4:09 pm
Did you mix it or use it in a lawnmower? It is 110 octane race fuel!!! I am sure you could mow some big weeds with that fuel. If you still have it unmixed give it to Dave I will need it at Hockenheim. If you used it send the can and funds with Dave THANKS.
PostPosted: Tue Aug 14, 2001 7:07 am
Sorry Bro It's not like it was going to help me that much anyway. But I did take out some huge weeds. I will give dave the $ . Did'nt mean to snake the Hawks food. JAZ
PostPosted: Tue Aug 14, 2001 7:30 am
Randy I must say I was pretty impressed this weekend. I am glad one third gen came out strong. I been thinking alot about what route to go my 350 or LS1 If I go with a 383 stroker kit what else would you reccomend to get 400 hp or higher. I am thinking about going with the twisted wedge heads and edelbrock 650 under drive pullys but I need help to find out what else I should go with. I Have Headman headers and flowmaster catback already. HELP!!! JAZ
PostPosted: Tue Aug 14, 2001 7:57 am
thanks Jaz, You could put together a 383 400 hp combo pretty cheap $3000 or so. You might find one at the race track this weekend already built. If you do not come I will keep my eyes open.
PostPosted: Tue Aug 14, 2001 7:21 pm
I was tinkering around looking for engine stuff/clutch when I found this site. They have some good stroker kits for cheap. Go figure, their site is called http://www.strokerkits.com. Found LT1 kit for $1500 and regular 350 kit for $1000!! Check them out.
PostPosted: Wed Aug 15, 2001 6:50 am
Thanks fellas I will check it out. Sweeny I think Tony has your gas can. The guy with the red truck said it was in the back of his truck. JAZ
PostPosted: Wed Aug 15, 2001 10:38 pm
Thanks Jaz
