It is currently Tue Aug 25, 2026 11:42 pm
 Post subject: break downs suck
PostPosted: Mon Aug 02, 2004 1:11 pm
Car took a dump on me last friday. Turns out its the fuel pump. Time to upgrade. Not sure if I will go with just the pump or a full racetronix pump and harness. Anyone got advise. I want to do it once so it needs to be able to support into the 600hp range.
PostPosted: Mon Aug 02, 2004 2:03 pm
If something is down, and you have to replace it, you might as well upgrade it. That is my theory! ;)
PostPosted: Mon Aug 02, 2004 5:01 pm
Get the racetronix kit Dave. Plug and play is better than splicin and dicin. That's what I have and took all of 10 mins to install after the tank was dropped.
PostPosted: Mon Aug 02, 2004 5:48 pm
Question is, how long did it take to drop the tank?
PostPosted: Mon Aug 02, 2004 7:00 pm
smart @ss :roll: :wink:
PostPosted: Mon Aug 02, 2004 7:21 pm
when I had to replace my feul pump it took only bout 10 min for the pump but due to the exhaust took 4 hrs to drop tank
PostPosted: Mon Aug 02, 2004 7:24 pm
I'm not being a smartass. I was just wondering
PostPosted: Mon Aug 02, 2004 10:10 pm
2 hrs to drop everything since my setup is easy but that tank was 3 hrs in itself and screwed the filler neck up in the process.... Others are lucky and it takes no time to drop the tank.
PostPosted: Tue Aug 03, 2004 2:58 pm
Turns out I was running lean. Good thing it took a fairly inexpensive part instead of my engine.
PostPosted: Tue Aug 03, 2004 5:15 pm
This is why I am not doing it myself. The tank is full too. I ended up buying just the pump (walbro w340) from Cmotorsports. They tell me it is a direct replacement.
PostPosted: Tue Aug 03, 2004 7:51 pm
Let us know how that direct replacement goes. :D They are never that unless it's a Racetronix unit. Trust me I KNOW. I've had them all.
PostPosted: Tue Aug 03, 2004 9:56 pm
You make my point above. I'll ask the mechanic doing it how hard it was after its done.
