Page 1 of 1
[ 14 posts ] |
Hawk
Post subject: Ford 9in rebuild Posted: Wed Aug 11, 2004 8:56 pm |
Getting ready to pull the 3rd member for a rebuild she is howling pretty bad.  I ran it with to much pinion angle on the bahn back from Eisinach last month and either junked a pinion bearing or change the wear pattern on the ring pinion setup. no lrge metal stuff just a buch of noise.
RobH
Post subject: Posted: Thu Aug 12, 2004 3:32 am |
| Senior Member |
Joined: Wed Apr 23, 2003 2:48 am Posts: 399 Location: Lawton, Ok
you know what i know, and besides the occasional shooting ourselves in the foot by to much pinion or whatever, the basic rule applies. You get what you pay for. There are several differant flavors of centers. Check out racingjunk.com, they may have a pro series. If your just doing bearings and little piddly stuff, you'll be doing it again.
Hawk
Post subject: Posted: Thu Aug 12, 2004 6:24 am |
got the 9in + good for 850 hapees but it did not like the pinion angle on the bahn.
NXZ28
Post subject: Posted: Thu Aug 12, 2004 6:29 am |
3 years of hard driving with that much horsepower will kill any gear. It was due a rebuild.
Post subject: Posted: Thu Aug 12, 2004 10:51 am |
Bruce If the third member was assembled with a crush sleeve on the drive pinion then that is more than likely the culprit . The drive pinion is walking the ring because the crush sleeve didn't hold its shape , due to your high horse power launches. Ford motorsports has an improved sleeve for this , an so does some aftremarket vendors. Eexcessive pinion angle usually chews up ujoints .
NXZ28
Post subject: Posted: Thu Aug 12, 2004 11:12 am |
@ Roy, That is exactly what happened. I looked at the ring gear personally. Pieces of the crush sleeve fell out into the carrier. The tooth patter is all off on the ring now. The gears are junk. The only thing I could do was to re-adjust his backlash so he could get one more weekend of racing in. He now has a complete rebuild kit with gears. Should be fixed by this weekend.
JackZ28
Post subject: Posted: Thu Aug 12, 2004 2:00 pm |
Hawk
Post subject: Posted: Thu Aug 12, 2004 3:04 pm |
It does not have a crush sleeve but it chewed a couple shims on the pinion throwing everything out wack.
Post subject: Posted: Thu Aug 12, 2004 9:12 pm |
NXZ28
Post subject: Posted: Fri Aug 13, 2004 7:39 am |
Has a shim ring.
Hawk
Post subject: Posted: Fri Aug 13, 2004 8:04 am |
yup shim ring can be taken apart and put back together.
Hawk
Post subject: Posted: Sun Aug 15, 2004 11:15 pm |
Done deal New gears/bearings pretty quiet now but I still hear a slightn whine. I will tighten the backlash a tad and I should be good.
Hawk
Post subject: Posted: Mon Aug 16, 2004 9:30 pm |
Roy/Val I still have a slight whine very minor but just jumpy before I start pounding on these gears and junk them it is very quiete @ 100 MPH. Noise changes slightley on decel to a slight moan.
NXZ28
Post subject: Posted: Tue Aug 17, 2004 8:08 am |
If it is moaning then it is enjoying the horsepower!  Actually we need to check that backlash after you drive it somemore.
Page 1 of 1
[ 14 posts ] |
Users browsing this forum: Google [Bot] and 1 guest |
