It is currently Mon Aug 24, 2026 3:43 pm
 Post subject: high speed vibration
PostPosted: Wed Oct 06, 2004 8:46 am
i noticed a vibration somewhere in my drivetrain from about 90mph-125mph anything above that speed and there is no vibration at all.... what could cause this ?
I did a search and most indicated the driveshaft as the problem source... I doubt that this is the case here, since the vibration is gone after 125mph.... do you think my poly tranmission mount could cause that problem ? Maybe even the Borla pipe that is almost touching something ? Weird thing is that its only from 90-125..
PostPosted: Wed Oct 06, 2004 10:13 am
Since you had your driveshaft out recently, I would go ahead and disconnect and rotate it 180 degrees and bolt it up again. Then run the test again. As for being wierd not really , as another vibration of a different freq could cancel it.
PostPosted: Wed Oct 06, 2004 10:17 am
Thanks Roy, I'll give it a try :wink:
PostPosted: Wed Oct 06, 2004 7:30 pm
IROC, it worked for me!!!!
PostPosted: Fri Oct 08, 2004 9:31 pm
If it still vibrates after the 180 degree turn, then turn it one more time 90 degrees. If you still feel vibration, then maybe wheel balance.
PostPosted: Sat Oct 09, 2004 5:19 am
Won't be abe to do a 90 , due to the fact the driline can only be mounted in two positions
PostPosted: Sat Oct 09, 2004 7:11 pm
Ahhh...I just crossed over from Stangland to the world of bowties, so excuse my post. I need to erase my mind of Ford tech on this board. :oops:
PostPosted: Sun Oct 10, 2004 7:03 am
Don't worry I still have pictures of my Mustang From 89. It whooped the hell out of 3rd gens over here in Germany.
