It is currently Fri Jul 10, 2026 2:55 pm
 Post subject: Bought me a Hooptie
PostPosted: Fri Oct 15, 2004 8:29 pm
I bought me a hooptie today. 89 Jeep Cherokee, 101,000 miles, leather interior, power everything. 4 wheel drive. Seems to be in good shape except for the paint job and possibly a short. Battery runs down in about 48 hours. Only gave $500 for it so I don't think I'll get hurt too bad. If anybody has suggestions on how to track down the short, I'd appreciate it. I know some people know how to find them. I don't know crap about electronics. May have to learn how to do bodywork and painting next summer.
PostPosted: Fri Oct 15, 2004 8:41 pm
Congrats :lol:
Pulling the fuses one at a time (with the engine not running) and measuring the current in the fuse socket is one possibility to find out what consumes power and how much... (radio and pcm is ok ;) )
Just my 2 cents.
PostPosted: Fri Oct 15, 2004 9:32 pm
That is a good way. You need to pull the fuses and find out where the short is at. Also you can pull the negitive side of the battery and hook a test light between the the post and the terminal end. If the light lights up then you have a short. If you need help, let me know and I will take a trip over to you and help you figure it out.
Best 1/4: 13.587 @100.90mph
PostPosted: Sat Oct 16, 2004 9:58 am
yeah I got a 1988 735i for the winter.....all leather and all power etc...and mines does the same too, if I dont drive or start it after 2-3 days I need to jump it :( overheats on me when i'm in heavy stop n go traffic too...but i think thats the T-stat because when i drive autobahn the temp guage goes colder and it takes forever to warm up in the morning.
Hey Rod, you want to help me put my headers and Y pipe on my bird? I'll make it worth the while..
2011 Chevy Camaro SS/RS
Sold my Bird to ChrisV6!
1998 Skyline GTS - SOLD!
PostPosted: Sat Oct 16, 2004 11:59 am
slickmetal.com wrote:
... overheats on me when i'm in heavy stop n go traffic too...but i think thats the T-stat because when i drive autobahn the temp guage goes colder and it takes forever to warm up in the morning.
might be thermostat but I had several older cars with that problem and this is typical for the cooling-cycle cut off somewhere, i.e. new head gaskets either not fit in perfectly or too much grease used which pressed in the wholes somewhere, or if there was a treaded radiator leak...
leave the heater wide open when hot outside and don't forget to have the extra gallon of water for the traffic jam and you good to go for many more years :D
 Post subject: Re: Bought me a Hooptie
PostPosted: Sat Oct 16, 2004 12:22 pm
KC10A wrote:
... If anybody has suggestions on how to track down the short, I'd appreciate it. I know some people know how to find them. I don't know crap about electronics. May have to learn how to do bodywork and painting next summer.
I would agree with HotRods suggestion - before I check every single fuse.
Also could be simply the battery itself getting older?
On the paint job - I haven't seen a Cherokee with a good one yet,
last thing to worry about.
But if you want it painted, I am sure Kamilla wants to help :wink: J/K
PostPosted: Sat Oct 16, 2004 8:23 pm
Thanks for the suggestions. Linda may have found my "short" for me. The glove compartment latch was loose so the light was staying on. I adjusted and tightened the latch and the light is staying off now. I hope I have my problem fixed. I have tried everything out except the cruise control and everything works, even the power external mirrors and both of the power seats. I'm a little surprised. Now if it turns out to be reliable, I'll be happy.
Rod, if the latch didn't fix my problem, I may take you up on your offer to help me fix it. I can come up there. I'll let you know if the batters is still discharging. It is a almost new battery.
PostPosted: Sun Oct 17, 2004 1:55 pm
@ Jerry--THe offer is still there. We can do it one of two ways, you can bring it to me or we can come up there to your place. I think coming over to your place would be better since the wife needs a shopping fix.
@ Mike--I can help you out with that. When do you want to do the exhaust. I have a friend that will let me use his garage and welder if we need it. Also we can use the drive over pit. I just don't want to use the hobby shop because you waiste 2 hours explaining and arguing with people that think that they know it all for an hours worth of work.
PostPosted: Sun Oct 17, 2004 5:49 pm
A question from the "uninformed": why is it called a "hooptie"?
PostPosted: Sun Oct 17, 2004 5:52 pm
Stef, that is basically ghetto slang for piece of crap daily driver! :D
PostPosted: Sun Oct 17, 2004 7:12 pm
Sounds a little fruity when you say it like that :wink:
PostPosted: Sun Oct 17, 2004 7:31 pm
Thanks Jack
PostPosted: Mon Oct 18, 2004 8:02 am
Leave it to the expert in those areas to correct me :roll:
AHAHAHAHAHAHAHAHAHAHAHAHA! Well said slick!
PostPosted: Mon Oct 18, 2004 8:04 am
[quote="HotRod]@ Mike--I can help you out with that. When do you want to do the exhaust. I have a friend that will let me use his garage and welder if we need it. Also we can use the drive over pit. I just don't want to use the hobby shop because you waiste 2 hours explaining and arguing with people that think that they know it all for an hours worth of work.[/quote]
I will PM you
