It is currently Tue Aug 25, 2026 7:46 am
 Post subject: 1991 TPI engine problem
PostPosted: Fri Jan 07, 2005 1:52 pm
Hi,
I don't know what has my camaro.
I have an enormous problem with my engine since 2 or 3 months.
First my engine sound has change, sound is more deep I think.
secondly when I start, during 2 minutes engine runs good. But after (when I drice), I lose power. It's not my automatic transmission because it is in good condition.
My engine has 50% power. When I accelerate I have no power. When I stop my camaro's engine runs good. When I stop my car during 5 or 10 mn and I start, engine warm, I have the same problem, I lose power after 2 minutes. I think it's the knock sensor or distributor probelm.
An othre problem is that my temerature engine is high. Normaly the first fan must to run at 195°F and the second at 226°F. But my first fan begins to run at 222°F and the second fan never (with air cond. I have just 1 fan works. I know that second fan work because I have tested it.
Do you know what's the problem?
Thank you very much
Alborz
1991 camaro Z28
V8 5.0L TPI (305F) TH700R4
PostPosted: Fri Jan 07, 2005 3:36 pm
Maybe a coolant sensor or O2 sensor.
PostPosted: Fri Jan 07, 2005 4:18 pm
I changed my cool temp sensor. May be i't Oxygen sensor. I must to change it to see if it's this.
PostPosted: Fri Jan 07, 2005 5:24 pm
I think you may have a weak ignition coil. When they get hot they tend to act up under a load.
PostPosted: Mon Jan 10, 2005 9:21 am
Hi,
I have change my knock sensor but it was not the problem. Now I 'll change the ignition coil. I have read the 1991 shop manual and I tested this and I think it's my ignition coild.
I think you have true NXZ28, thank you.
PostPosted: Wed Jan 12, 2005 3:15 pm
yesterday I changed my ignition coil, distributor cap + rotor, spark plug wire. I think engine runs better but still I lose power. this week-end I'll change my spark, I have Bosch HR10BC, I replace by HR9BP platinum.
Do you know how I can test my bille distributor please?
PostPosted: Thu Jan 27, 2005 8:15 pm
change the O2 sensor... could be the problem.
http://www.cardomain.com/id/unexplained666
CHEVROLET- Cheap, Hardly Efficient, Virtually Runs On Luck Every Time
PostPosted: Sat Jan 29, 2005 10:26 am
Hi,
I changed my O2 but I have the same problem. I lose power after 2 or 3 minutes. My spark plug have carbone deposite, Now my car drink 32 liters per 60 miles :shock: :shock: :shock:. I think it's a fuel problem or maybe the canister, my billet distributor???
When I drive my engine has hesitations as far as 75 miles/hour, after 75 miles/h engine runs good and when I stoped it runs well.
It's a serious problem for me because I don't understand why I have this problem. I changed the distributor cap + rotor, spark plug, spark plug wire, knock sensor, CTS, fuel filter, O2, :crazy: :crazy: :crazy:
Next week I'll go to see a friend and test the fuel pressure...
Thanks
PostPosted: Sat Jan 29, 2005 5:48 pm
1991Z28 wrote:
Hi,
Thanks
ok, i'd check these things in this order:
1. Coil
2. plug wires
3. spark plugs
4. O2 sensor
5. ignition parts
6. ECM - check if there are any trouble codes
7. MAF
hmmm if anything comes to mind i'll add it later
PostPosted: Mon Jan 31, 2005 8:32 am
hi,
1- Coil ingition ok and changed (MSD dual)
2- plug wires ok and changed (MSD 8.5mm)
3- spark plugs ok and changed (bosch HR9BP)
4- O2 ok and changed (bosh)
5- ignition parts, I must to test all
6- ECM, I have no code, I have tested
7- 1991 camaro have not MAF sensor
I really think that's a fuel problem. :arrow: I must to test the fuel pressure.
PostPosted: Mon Jan 31, 2005 12:03 pm
1991Z28 wrote:
hi,
check the fuel pressure, fuel pump could be damaged.
CHANGE THE FUEL FILTER - it might be clogged
check fuel injectors
how about the MAF/ MAP?
PostPosted: Wed Jul 06, 2005 11:19 am
Hi everybody,
Just to say you that my 1991 Z28 runs very good now.
Really I don't know why??? After 6 months of problems, my engine have no lost of power or hesitation.
TPI engine is a mistery for me????
Thanks
ALBORZ
1991 Z28 V8 5.0L TPI TH700R4
Users browsing this forum: Google [Bot] and 1 guest
