Nazman
Post subject: Posted: Mon Mar 07, 2005 10:11 pm |
Joined: Wed Feb 04, 2004 8:39 pm Posts: 177 Location: Gernsheim, Germany
NXZ28 wrote: SyGoat wrote: Nazman wrote: Yes, I'll run NA as well. We are talking 1/4 mile here. No, I dont run 4.10 gears., that was only a test, not enough gear for the 4V. I run a bit more...lets just say 4.30+s  And yes, you could ask several your F-Body brothers, she will run 170+s MPH with the "4.30s" on the "big end". Bring that Goat of yours and I'll show you. Is all for fun brothers, dont get all out of wack. The season is coming and we have to start the "hating"! Naz 1st 3.37 2nd 1.99 3rd 1.33 4th 1.00 5th .67 4.30 rear, 170mph = 6410 Is that correct? What size tires? I pushed my Z to 6600rpm in overdrive (automatic) with 3.23 gears and P245/50 R16. I think they are 25.1 tall tire. I don't know how fast I was going but it was getting hard to see. Braking was the hard part.
Bro,
You realize that is over 210 MPH, not saying that the LS1 is not capable, or you did not do it, but you are making some MAD power and some serious aerodynamics to match if tat is the case.
You sure you did not mean 5600s? That is more like it, since is about 180 MPH (give or take a few).
Naz
_________________ Garden Snake
TurboManiacal
Post subject: Posted: Mon Mar 07, 2005 10:37 pm |
Joined: Tue Sep 21, 2004 12:43 pm Posts: 963 Location: Mannheim
Nazman wrote: SyGoat wrote: Nazman wrote: Yes, I'll run NA as well. We are talking 1/4 mile here. No, I dont run 4.10 gears., that was only a test, not enough gear for the 4V. I run a bit more...lets just say 4.30+s  And yes, you could ask several your F-Body brothers, she will run 170+s MPH with the "4.30s" on the "big end". Bring that Goat of yours and I'll show you. Is all for fun brothers, dont get all out of wack. The season is coming and we have to start the "hating"! Naz 1st 3.37 2nd 1.99 3rd 1.33 4th 1.00 5th .67 4.30 rear, 170mph = 6410 Is that correct? What size tires? O/a correct, I think that I have recored about 6500+ RPMs on the Autotap. Tire size is: 275/40/17s or 25.7 inch Naz
Kewl...let me get the same amount of money mods in my GTO and I'll take you up on your $25 bet...only on the Autobahn...100-150 run.
_________________ 2008 BMW 335xi
NXZ28
Post subject: Posted: Tue Mar 08, 2005 3:44 am |
Nazman wrote: NXZ28 wrote: SyGoat wrote: Nazman wrote: Yes, I'll run NA as well. We are talking 1/4 mile here. No, I dont run 4.10 gears., that was only a test, not enough gear for the 4V. I run a bit more...lets just say 4.30+s  And yes, you could ask several your F-Body brothers, she will run 170+s MPH with the "4.30s" on the "big end". Bring that Goat of yours and I'll show you. Is all for fun brothers, dont get all out of wack. The season is coming and we have to start the "hating"! Naz 1st 3.37 2nd 1.99 3rd 1.33 4th 1.00 5th .67 4.30 rear, 170mph = 6410 Is that correct? What size tires? I pushed my Z to 6600rpm in overdrive (automatic) with 3.23 gears and P245/50 R16. I think they are 25.1 tall tire. I don't know how fast I was going but it was getting hard to see. Braking was the hard part. Bro, You realize that is over 210 MPH, not saying that the LS1 is not capable, or you did not do it, but you are making some MAD power and some serious aerodynamics to match if tat is the case. You sure you did not mean 5600s? That is more like it, since is about 180 MPH (give or take a few). Naz
210? That was the engine temp.  Bruce, Jeff, and myself were racing on the way back from the October Bitburg. Once the speedo went past 155, I could only glance at the tach. My computers rev limiter is set at 6800 so I was keeping an eye on it. LS1 and rev limiters = broken oil pump. Unless I am crosseyed, it was well past 6000 because I had to let off it. I just tell it how I see it. I know it was somewhere around 170 mph.
Firechicken
Post subject: Posted: Tue Mar 08, 2005 9:08 am |
Roy,
You going to up and running for APRs event??? I've got the cure for James' Focus......yes I will have them with me too!!!
Naz,
what was the outcome with you, Bruce, & Jeff coming back from Bitburg??? Are you still going to come over to the "twistie" side of the house this year or is it 1/4mi only???? Any of your Bro's in the M/M game for the auto-x/road course stuff????
Val
Retired US Army
Garry
Post subject: Posted: Tue Mar 08, 2005 10:18 am |
They way Bruce was talking last year, he better be doing some AutoX this year!!!  Wonder how bad his @ss be kicked by one Ford Focus that will be back soon ...
NXZ28
Post subject: Posted: Tue Mar 08, 2005 5:42 pm |
Firechicken wrote: Roy, You going to up and running for APRs event??? I've got the cure for James' Focus......yes I will have them with me too!!!
Naz, what was the outcome with you, Bruce, & Jeff coming back from Bitburg??? Are you still going to come over to the "twistie" side of the house this year or is it 1/4mi only???? Any of your Bro's in the M/M game for the auto-x/road course stuff????
Val
Val, that was myself, Bruce, and Jeff racing back from the October Bitburg. We all stayed pretty even unitl Jeff got pinned behind a slower car and then Bruce and myself were running side by side. Of course he was ailing from a slipping clutch. Then I let off because of the automatic / rev limiter problem. So I guess you could say Bruce came out on top. Then Bruce and Jeff went at it again and I think Bruce took that one also.
Squirrelina
Post subject: Posted: Tue Mar 08, 2005 7:28 pm |
Joined: Sat Apr 13, 2002 2:00 am Posts: 2530 Location: Höheischweiler, SüdWestPfalz
Nazman
Post subject: Posted: Tue Mar 08, 2005 10:25 pm |
Firechicken wrote: Roy, Naz, Are you still going to come over to the "twistie" side of the house this year or is it 1/4mi only???? Any of your Bro's in the M/M game for the auto-x/road course stuff????
Val
I'll like to try it a couple of times. Trying to figure out a balance in the suspension set-up.
Tokico 5 Way adjustable Struts (Drag) provide one setting for "agressive" street driving, the other 4 are DR/Street oriented.
Right now running Lakewood 90/10s and Drag Springs which made the car handle like a boat! It really sucks.
So, right now Im working a solution. Im swapping the front springs to V6 springs, that will bring the nose down a bit and help with aerodinamics but still handle like a boat.
Then the rears, running Drag springs as well and Lakewood 50/50s and an air bag.
I just want a sub-1.50s 60fts and Ill be happy. Then, Ill go back to the H&R Super Sports and Blistein shocks/struts combo w/some Avalon RC oriented tires and some serious help with the driver!
May be I let Roy take her for a ride and so he could show me how is done.
But to answer your Q, yes Ill try a few times.
Naz
Firechicken
Post subject: Posted: Wed Mar 09, 2005 5:19 am |
COOL, look forward to seeing you over there. I'm set up for the twistie stuff but am going to try for mid to low 12s in the 1/4 this season. I won't change my set up except for tuning the computer.
Retired US Army
Users browsing this forum: No registered users and 84 guests |
