It is currently Mon Aug 24, 2026 5:21 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu May 26, 2005 2:49 pm
yeah that is the same converter I use.
Acouple questions
What gear did he use?
Was he able to lock the torque converter?
I doubt he locked the coverter and I am not sure what gear he ended up using.
How should he do it? Next time I go, hopefully after the cam, I will make sure it is all done right.
PostPosted: Thu May 26, 2005 6:17 pm
It looks like it was done in second gear. Unless that itty bitty blip was a shift to third. I doubt it because the rpms are to low to beable to hold 3rd at wide open.
PostPosted: Mon May 30, 2005 5:47 am
Fast GTO wrote:
BTW anyone know how to convert the German Lambda to A/F ratios?
Try this.
http://www.rbracing-rsr.com/rsrairfuelmeterl.htm
Scroll to the bottom of the page.
Naz
Garden Snake
PostPosted: Fri Jun 03, 2005 4:03 pm
Nazman wrote:
Try this.
Naz
WOW!
Thanks bro.
So I need to use the Gasoline # which puts me at about 13.083 for A/F....
Is that considered too rich?
PostPosted: Wed Jun 29, 2005 5:47 pm
Anyone did a dyno tune at this shop?
PostPosted: Wed Jun 29, 2005 8:41 pm
I don't think no one has done a dyno tune. Just dyno runs. Where are you based at? I see you are SC what all have done to the car?
PostPosted: Wed Jun 29, 2005 8:56 pm
Blower cam, ATI P1 at 7PSI, 499RWHP . I was thinking of adding supermaxx exhaust system and upgrade my intercoolers. Heidelberg.
PostPosted: Wed Jun 29, 2005 9:14 pm
I know of at least one guy around here that takes his mustang down there for tunes. He seems happy with him.
PostPosted: Thu Jun 30, 2005 7:47 am
Hey can you find out more info on that guy? Like the yr of the car and what program they use whether it be SCT, HP, etc?
PostPosted: Thu Jun 30, 2005 12:22 pm
Let me see what I can do.
