It is currently Thu Apr 16, 2026 11:47 am
 Post subject: Just when I thought I beat the oil problem. LOL!
PostPosted: Tue Jul 26, 2005 8:07 pm
Man..........stumped for words at the moment collecting my thoughts. Brand new 10/30w oil and hoped it would cure my erractic oil pressure after warm up and it didn't. So I changed to 20/50 and everything looked good and I could tell a immediate difference in the readings at initial startup (thinking to myself ok a heavier weight then)...but after 10 mns it starts fluctuating again. Now w/ the 10/30 dino oil it would jump 15 psi either direction but never drop under 20psi @ idle....w/ the 20/50 it only jump 5-10 psi either direction and never drop under 40 psi @ idle.
So my question for today is how accurate is the mech guage? I mean I know it's accurate but has anyone run one on perfect sound engine and still see fluctuation in oil pressure no matter how big or small?
I planned on putting new bearings in this spring but I just wanted to be sure before doing it. Thanks!
PS.. WHAT THE HELL IS THE CAUSE OF VOLTS DROPPING UNDER SLIGHT LOAD AND THEN SHOOTING BACK UP 10 12.5 TO 13v?! I''ve cleaned all the contacts ground and positive w/ no luck! ARGHHHHHHHHHHH!
The "SRZ"
PostPosted: Wed Jul 27, 2005 5:25 am
John,
did you have that crank turned ......ever??? My 455 at home did the same thing and that had 10/10 bearings. Oil pressure never dropped below 20psi but all that I have talked to say it's due to the different bearing size. Did you have any metal shavings???? Got me on the voltage thing.
PostPosted: Wed Jul 27, 2005 5:35 am
John , I would check out that pump. Sounds like it could be loose , or the pickup is too high , or the there is a problem with the relief spring.
As for the alternator, 12.5-13 vdc is not enough voltage too charge a battery at idle. Do you have a under drive pulley on the crank and the alternator. Does the voltage jump up to 13.5-14 vdc at a higer idle , lets say 2500 rpms?
PostPosted: Wed Jul 27, 2005 6:00 am
Val the crank was repolised and I use standard bearing when it was rebuilt.
Metal shavings? Oh yeah......I chips all in the filter from the 1st layer of the bearings it appears. I haven't cut this filter open yet as it's still new but I flushed the engine w/ at least 50 qts of oil to make sure I got it all from inside the pan as I had a few normal deposits on the drain plug and one 1/2" sliver on there as well. :( Why the damage so early on is any ones guess. I over shot the rpm's once in a missed shift but I don't ever hear anyone else mention oil problems from something like that.
Rebuild is all I can come up with....it would be nice if it was the pump or the relief spring. Too make sure though I'll be buying a new pump along w/ a custom oil pan as this has nothing in it at all.
The volt thing........I'm clueless on. Not under crank pulleys. My pwr steering pump isn't making noise's either so I don't know where to go. Should've bought a volt meter like I was supposed when I was stateside but didn't.
To answer you other question Roy it looks like it goes higher past 2500 it's above the middle mark.
Roy you have a meter?
PostPosted: Wed Jul 27, 2005 6:26 am
Does a chicken have tits? Can I run into wall? Of course I have a multimeter , but I am currently on vacation in beautiful Bayern and won't be back to help till second week of August.
PostPosted: Wed Jul 27, 2005 7:48 am
LOL! Enjoy your vacation. Just give me a holla when ya get back and have settled in.
PostPosted: Wed Jul 27, 2005 10:00 am
I can look at it next week when you come down.
Owner JZ Customs
Binsfeld GE
PostPosted: Wed Jul 27, 2005 11:13 am
That'll work too. Thanks Jaz. Hopefully I'll have the new alternator in along w/ the battery cable kit.
PostPosted: Wed Jul 27, 2005 12:49 pm
Im about to throw mine down the street. I just put in a MSD 160 amp and its bad. :rant: Im getting real sick of this. So now I have all that crap in my car and no Alt. I wire it up everything is good. I drive down the street it cuts off then cuts back on when its ready too. :bash:
Owner JZ Customs
Binsfeld GE
PostPosted: Wed Jul 27, 2005 2:17 pm
Man that sucks! I swear I love this car...I really do but when it does down it goes down hard w/ a bang! I've got a spare but it's only a 105a you'll kill that sucker in no time. See mine don't cut off it'll run but it just runs like crap in the 2500rpm range and after that it's ok.
We can drop em' off a cliff together if you like. :lol:
PostPosted: Wed Jul 27, 2005 2:19 pm
Sounds good.
Owner JZ Customs
Binsfeld GE
PostPosted: Wed Jul 27, 2005 5:59 pm
We can drop em' off a cliff together if you like. Laughing
before anybody does anything silly. I will take free cars all day long just let me know. I will have my commander signing the waiver to regester more cars over and over again
thank you have a nice day
PostPosted: Thu Jul 28, 2005 12:40 pm
ha-ha....I'll keep you in mind if it ever comes to that. Highly unlikely/impossible but I'll still keep ya mind. :D
PostPosted: Thu Jul 28, 2005 1:02 pm
Mines possesed :twisted: Trust me you dont want that Spoiled lil Bitc#.
Owner JZ Customs
Binsfeld GE
PostPosted: Tue Aug 02, 2005 5:09 pm
Voltage cured. See general section. :D
