Page 1 of 1
[ 15 posts ] |
Lancer033
Post subject: Winter Upgrades - step 1 Posted: Tue Sep 20, 2005 5:54 pm |
Joined: Mon Aug 09, 2004 6:27 pm Posts: 846 Location: Hampton, VA
NXZ28
Post subject: Posted: Tue Sep 20, 2005 6:08 pm |
Nice. What is step 2?
jinstall
Post subject: Posted: Tue Sep 20, 2005 8:36 pm |
Joined: Tue Jul 12, 2005 5:08 pm Posts: 942 Location: Fort Bliss, Texas
Step 2 slicks
_________________ 2001 Ford Focus sleeping in Germany 04 Focus ST170 Clone in USA 2010 Renault Clio 1.2 16V in Germany 2013 Focus ST250 in the USA 1st car 77 Camaro Type Lt 5.0 auto
Lancer033
Post subject: Posted: Tue Sep 20, 2005 9:08 pm |
yep, That's the only way I've got a chance against those Dutch guys, Val , Roy and you. Going to pick up a set of used C4 GS wheels and either Kumho V710s or Hooser A3SO5s, probably the 710s.
after that, shocks and swaybars, then some simple exterior/interior dress up/ upgrade things. If I've got enough left over, a new radiator w/ built in oil cooler and a trans/diff cooler
also going to cut this street/track best of both worlds crap out and do a full track alignment and see how much camber I can get out of this thing with some Hardbar camber plates ( http://hardbar.net/page_corvettesuspension.htm). so much for the inside of my tires  .
after that, a 4th set of wheels with either Toyo RA-1s or Nitto NT55R2s just for the ring.
The only downside is that these calipers will bump me to SM2 if I autoX with the SCCA when I get back to the states. Guess I'm going to have to figure out where to shave some weight off this pig.
on top of that, I've got to figure out what all is wrong with my BMW and get the thing running good again before it starts snowing. Hopefully it's just the water pump and a few bad coolant lines
TurboManiacal
Post subject: Posted: Wed Sep 21, 2005 6:55 am |
Joined: Tue Sep 21, 2004 12:43 pm Posts: 963 Location: Mannheim
Well I started my Wilwood conversion yesterday...and managed to yank the caliper bolts out of their threads in the bracket. I'm a little pissed...ok ALOT pissed.
Going to try a work around today. Give me a call when you get ready to do your swap and I'll try to guide you around the pitfalls.
_________________ 2008 BMW 335xi
TurboManiacal
Post subject: Posted: Wed Sep 21, 2005 4:26 pm |
Well just got done with my Front Wilwood install. Lots of learning points. The immediate take home point is for you to see if your vendor will pre-build your rotors for you.
Knowing that you are AF and located on an AF base...it might not be that hard to find an plane mechanic that can safety wire your rotors for you, but I didn't know how to do it...and luckily there was a guy here who happened to be there at the Auto Craft shop that did.
Lancer033
Post subject: Posted: Wed Sep 21, 2005 10:39 pm |
spade
Post subject: Posted: Thu Sep 22, 2005 12:58 am |
Joined: Sun Dec 22, 2002 10:44 pm Posts: 152 Location: Belgium
I wish I could go with the Wilwood package. My Fiske rims will not allow them to fit though. The only option I have is the LG ZO6 brackets. Now if I had 18's it would be a different story.
TurboManiacal
Post subject: Posted: Thu Sep 22, 2005 6:36 am |
for right now I'm going with the wilwood pad that came with the kit. I'm more concerned now about figuring out what I need to do in the rear. If I need to go as agressive and get a wilwood rear kit or if I can squeak by with 05 rotors and upgraded pads on the stock calipers. I'm going to hit nordschleife on sunday with ben I think.
BenZ28
Post subject: Posted: Thu Sep 22, 2005 9:28 am |
Lancer033 wrote: the main advantage of the kit i'm getting is that I will still use my $25 stock rotors.
 What kind of rotors are you running that cost only $25? ...and I thought my Brembo OEM rotors at $60 a piece were relatively cheap.
Lancer033
Post subject: Posted: Thu Sep 22, 2005 5:35 pm |
BenZ28
Post subject: Posted: Fri Sep 23, 2005 12:53 pm |
Cool, how long do these rotors last on your car; I mean in what intervals do you replace them?
Garry
Post subject: Posted: Fri Sep 23, 2005 1:01 pm |
... and will they fit a stock '98 F-Body setup?  I'm afraid that running a weekend of AutoX in Bitburg next week the new used rotors from Jack will probably be warped beyond usage again ...
Lancer033
Post subject: Posted: Sat Sep 24, 2005 11:31 am |
Lancer033
Post subject: Christmas in October Posted: Tue Oct 11, 2005 8:40 pm |
Page 1 of 1
[ 15 posts ] |
Users browsing this forum: No registered users and 74 guests |
