It is currently Tue Aug 25, 2026 1:54 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Oct 04, 2005 7:49 am
I have a CAI, Long Tube Headers, Full 3" Catback, Plugs/Wires, and Predator tune.
Full Bassani Exhaust
AEM Meth Injection
PostPosted: Tue Oct 04, 2005 9:44 am
spade wrote:
I plan on running that same cam here soon I think because it will be nice with me procharger. :twisted: On that note I have never done a cam install myself but there are plenty of guys who have. You could always go to http://www.ls1howto.com for all the info you need on doing a cam swap. If I was closer I would help so we could both learn. Crash course on your car. :D
Woah...lots of info here.
http://www.ls1howto.com/index.php?article=23
PostPosted: Tue Oct 04, 2005 1:07 pm
Well if Ryan gets the cam he wants then we can just have an FBODY meeting organized around installing 3 cams!
AEM Meth Injection
PostPosted: Wed Oct 05, 2005 4:34 am
I have a shop in Bamberg that we can use. It has a lift in it also. Only catch is that we have to do the install on the weekend.
PostPosted: Wed Oct 05, 2005 8:49 pm
Best time to do it!
We will just have to sleep in the bay....
:wink:
NXZ28, do you work at the auto craft in Bamberg?
I actually need my exhaust adjusted but the guy who installed it initially tac welded the clamps down so it needs to be cut off. Shouldn't be too much work, he just did little half inch welds.
Ah well, just let me know when you are back in town and I'll stop down your way.
I actually headed out to Schweinfurt today to check out my new stomping grounds.
WAAAAAAAAAAAY too many rustangs for my liking.
:twisted:
But I think my car scared most of them with its bark.
AEM Meth Injection
PostPosted: Thu Oct 06, 2005 4:08 am
Fast GTO wrote:
Best time to do it!
:wink:
:twisted:
I am in the Army. I run a motorpool on Muna Kaserne. My Battalion Commander lets us work on our cars in the motorpool on days off. A few rules though. Safety, Non-Profit work, and no use of government materials like oil, grease, filters, or parts. It works out pretty well. My car did get stuck on the pit one Sunday and I barely got it out before work started the next day. As for the Mustangs in Schweinfurt, they all migrated from Bamberg. Sorry about that. :D
PostPosted: Thu Oct 06, 2005 2:12 pm
This is unconfirmed reporting....
If things go as planned on my move to Schweinfurt I will be pocketing the rent deposit I have already paid on my current place.
That is 3K EURO!!!!!!
Stage III Heads and a Cam will then be purchased....400 RWHP LOOK OUT!
BTW, this is only assuming that I don't have to give it back to finance, and I don't think I wil since I think they have been taking it out of my check every month so far.
:twisted:
AEM Meth Injection
PostPosted: Thu Oct 06, 2005 2:26 pm
sweet
PostPosted: Fri Oct 07, 2005 9:04 pm
Okay the custom cam is a go.
8)
In two weeks I will know if the Stage III heads are a go as well.
The heads will come pre-assembled with all the necessary valvetrain upgrades so all I will have to do is swap my rockers on to them.
:twisted:
AEM Meth Injection
PostPosted: Sat Oct 08, 2005 4:37 am
Sounds good. Your going to need some rear end upgrades after this. You should be in the mid 12s easy.
PostPosted: Sat Oct 08, 2005 7:28 am
I am in Bamberg now so. I would go with cam only with a good tune.
PostPosted: Sat Oct 08, 2005 9:02 am
GTO Rearend is good to the low 12's.
BMR tested it out substantially via their 9 second GTO.
Weakest link is the two piece driveshaft.
I appreciate the enthusiasm on wanting to help me with this. The cam is a definant go, the heads will be decided in about two weeks (my better half says that the extra money is better spent invested or paid towards something).
:roll:
AEM Meth Injection
PostPosted: Sat Oct 08, 2005 9:52 am
:roll:
heads are an investment!! you just wont get a very good return. hehe
maybe it is just a high risk invenstment that went the wrong way. :lol:
PostPosted: Sat Oct 08, 2005 6:43 pm
Well heads really do seem to be that aspect that opens up the cams potential.
Most GTO's with just a cam and my mods are between 360-385 depending on how aggressive (mine is going to be mild). The addition of heads pushes them to the 400-425 region.
Either way the cam is a go so I'll be happy with that if I don't end up with the heads.
AEM Meth Injection
PostPosted: Sat Oct 08, 2005 7:20 pm
Don't go too small on the cam. You should go for something like I have. 224 / 228 duration .581/ .588 lift and 114 LSA. Very streetable and alot of power on stock heads. Lopes some too. Put down 393 rwhp on the dyno. I am glad now that I did not get the .561 lift cam. Way too small for an LS1 that likes to rev. Just my opinion though.
PostPosted: Sat Oct 08, 2005 8:49 pm
You shoulda beleived me I told you that was a nasty cam. I got a TREX for you now. LOL
PostPosted: Sun Oct 30, 2005 9:48 am
Before you start, I recommend the following:
1. Get the longer crank pulley bolt listed on ls1howto.com do it!
2. Make sure you have several different pulley pullers or one that is proven to work on ls1's
3. PLAN ON A TUNE, whether u have an M6 or auto, you'll want it tuned.
4. Since you're a self proclaimed noob, do some searches and reading on ls1tech.com.
5. LS6 springs are only good for wimpy cams; like my hotcam or an ls6
6. print, read, and re-read the ls1howto article 10 times
7. get a new oil pump pickup o-ring!!!! http://www.shinken.us/tickingLS1.html
So many people, including myself, have done a cam swap and sh*t themselves after, thinking theyscrewed up because of a bad o-ring.
8. The lifter holding tools work awesome, I was glad I got them.
9. USE A TORQUE WRENCH ON ALL BOLTS THAT GO INTO ALUMINUM OR YOU WILL STRIP THEM! ie oil pump bolts, oil pan bolts and pretty much all others since we have an aluminum block.
10. Read about valve spring compressor tools. Almost none of them work under our cowl. I have a picture or how to make one somewhere, I'll look for it.
11. Give yourself more than one day. I started on a friday night and finished on sunday morning at the craft shop.
PostPosted: Sun Oct 30, 2005 2:27 pm
I've got everything that is needed to do a cam install in the car to include a valve spring compressor that works GREAT under the F-body cowl. I know of 3 other people on the board that if gotten together can knock it out in a day.....
PostPosted: Mon Oct 31, 2005 9:37 am
Good.
Priorities change and reason has kicked in.
I'll be getting the LPE GT2-3.
:wink:
AEM Meth Injection
PostPosted: Mon Oct 31, 2005 3:46 pm
Were did you get your spring compressor from? I am looking into getting a cheap one to use as well.
