TurboManiacal
Post subject: Hey Stef...How long are the S4 Engines Good For? 20k? 30k? Posted: Mon Apr 24, 2006 5:29 pm |
Joined: Tue Sep 21, 2004 12:43 pm Posts: 963 Location: Mannheim
Miles? Cause apparently the 2.0T in my wife's car is only good for 12k miles. I figure if you upgrade to the better B7's you get more mileage out of them.
_________________ 2008 BMW 335xi
2slow
Post subject: Posted: Mon Apr 24, 2006 6:04 pm |
Joined: Sun Jul 04, 2004 11:34 pm Posts: 653 Location: Wolfsburg, Germany
12 K miles??? Who told you that CR*P? or did you manage to blow it up?
Most engines are laid out for a minimum of 100 K km (60 K miles) worth of thrashing before they will need work (as in emissions, not like new bearings or broken conrods).
_________________ Life served me a lemon.... I made Lemonade out of it!
TurboManiacal
Post subject: Posted: Mon Apr 24, 2006 6:08 pm |
2slow wrote: 12 K miles??? Who told you that CR*P? or did you manage to blow it up? Most engines are laid out for a minimum of 100 K km (60 K miles) worth of thrashing before they will need work (as in emissions, not like new bearings or broken conrods).
The Audi Dealership right across from the Kaserne here on B38 in Mannheim. I didn't blow it up...Hell I never get to drive the car. The wife is DEATH about this being HER car. (She does make the payments after all) The only time I even remotely drove it hard was a one lap around the Auto-X. And even then I didn't even thrash on it.
#2 cylinder has zero compression. I'll know more by Wed on direct cause (piston / valve etc). Don't happen to have a spare V8 (or even V10) laying around you could donate to the cause?
Garry
Post subject: Posted: Mon Apr 24, 2006 6:40 pm |
Sounds like a manufacturer's defect ... piston rings or something ... shouldn't go bad that early ... get it fixed under waranty
2slow
Post subject: Posted: Mon Apr 24, 2006 6:45 pm |
TurboManiacal wrote: Don't happen to have a spare V8 (or even V10) laying around you could donate to the cause?
I know where's a spare R8 Le Mans race motor, but the fences are high and the security wears jackboots............
So far the S4 has run faultless (10 K km) except for noticable tire wear in the front. Getting a RS4 in June, then there will be VERY noticable tire wear all round.
Let me know what was the problem with the wife's car and I can check if similar problems have happened before.
Garry
Post subject: Posted: Mon Apr 24, 2006 6:49 pm |
2slow wrote: noticable tire wear in the front [ ... ] Getting a RS4 in June, then there will be VERY noticable tire wear all round.
How's that?
TurboManiacal
Post subject: Posted: Mon Apr 24, 2006 7:05 pm |
I'll let you know what the exact cause was. We broke the car in right and were changing the oil at the right intervals. We even had the services done early. The wife drives it so you know it's not driven hard but dang...this is frustrating.
I guess stateside you get a loaner with your warranty service...wonder with our US Warranty if we still get that option. Would be nice...time to call up USAA also to see if they reimburse under this situation.
jeejee
Post subject: Posted: Mon Apr 24, 2006 9:47 pm |
man that sucks bigtime
i hope the misses doesn't see this as a sign never to buy a sporty car anymore
maybe just a bent valve ....
not that that should happen afcourse with "normal driving"
TurboManiacal
Post subject: Posted: Tue Apr 25, 2006 7:46 am |
If I were a betting man...I'd stay stuck or bent valve as the power levels seemed normal...it just idled really rough and threw a code. I hope it's an easy fix and can be repaired by tomorrow when the dealership promised.
Lancer033
Post subject: Posted: Tue Apr 25, 2006 10:17 am |
Joined: Mon Aug 09, 2004 6:27 pm Posts: 846 Location: Hampton, VA
jinstall
Post subject: Posted: Tue Apr 25, 2006 11:29 am |
Joined: Tue Jul 12, 2005 5:08 pm Posts: 942 Location: Fort Bliss, Texas
2slow wrote: TurboManiacal wrote: Don't happen to have a spare V8 (or even V10) laying around you could donate to the cause? I know where's a spare R8 Le Mans race motor, but the fences are high and the security wears jackboots............ So far the S4 has run faultless (10 K km) except for noticable tire wear in the front. Getting a RS4 in June, then there will be VERY noticable tire wear all round. Let me know what was the problem with the wife's car and I can check if similar problems have happened before.
LOL Got a MGRS 10 digit for us? There are a few of use that could risk it.
_________________ 2001 Ford Focus sleeping in Germany 04 Focus ST170 Clone in USA 2010 Renault Clio 1.2 16V in Germany 2013 Focus ST250 in the USA 1st car 77 Camaro Type Lt 5.0 auto
2slow
Post subject: Posted: Tue Apr 25, 2006 7:26 pm |
Latitude 48.7944
Longitude 11.4107
Bulshit your way past the guards at the gate, see if you can crack the keycard entry and plan your escape route when the silent alarm goes off.
Good luck.
TurboManiacal
Post subject: Posted: Tue Apr 25, 2006 7:44 pm |
2slow wrote: Latitude 48.7944 Longitude 11.4107 Bulshit your way past the guards at the gate, see if you can crack the keycard entry and plan your escape route when the silent alarm goes off. Good luck.
Will we have time to install the engine into our getaway car?
TurboManiacal
Post subject: Posted: Tue Apr 25, 2006 7:49 pm |
I see my engine.
Garry
Post subject: Posted: Tue Apr 25, 2006 7:51 pm |
2slow
Post subject: Posted: Tue Apr 25, 2006 7:54 pm |
There's airlines on the wall and airtools in the cupboards. Might have to practice a bit to do it in the dark though.
jeejee
Post subject: Posted: Tue Apr 25, 2006 9:26 pm |
TurboManiacal
Post subject: Posted: Tue Apr 25, 2006 9:31 pm |
jeejee wrote: how about that tour guide ?
Stef says we need to plan a weekend were the Americans bring the beef, the dutch bring the bierje and he provides the house, billiards and tour.
jeejee
Post subject: Posted: Tue Apr 25, 2006 9:42 pm |
Lancer033
Post subject: Posted: Tue Apr 25, 2006 10:09 pm |
Users browsing this forum: No registered users and 16 guests |
