It is currently Tue Aug 25, 2026 12:00 pm
 Post subject: Strano Lowering Springs Question
PostPosted: Thu Nov 02, 2006 10:40 pm
Anybody on here know anything about the Strano lowering springs? I'm thinking about ordering a set. Will they handle pretty well for normal driving. Are they firm enough to be uncomfortable or just good handling springs. Is a 1.25" drop enough to cause problems with dragging on everything? I've already got the Konis to put on. I'm either going to order lowering springs or do the "heater hose mod. Suggestions or comments please.
PostPosted: Thu Nov 02, 2006 10:42 pm
Do you have SFCs? If so, watch out how low you put your car ... I have problems with my 'maro in the driveway ...
PostPosted: Fri Nov 03, 2006 5:32 am
I have no input on the lowering springs.
PostPosted: Fri Nov 03, 2006 7:27 am
Everything I've read about them so far has been othing but positive. Sam put them on his car that he took to race and won... again... lol I'm considering getting rid of my BMR springs in favor of Strano's. :)
Brian
'01 Camaro SS #0034
338 RWHP
353 RWTQ
PostPosted: Fri Nov 03, 2006 8:42 am
Remember how low my T/A sat, if so raise it up about 1/2in. I had SFC's on it and had no scraping problems. The headers where lower than the SFCs and they never scraped. The Strano springs have a 500lbs spring rate in front and 150lbs back(rears are a progressive spring (150-180)). It should be forgiving (not abusive) for daily driving and handle AlOT better than stock. I'd buy them but I'm still sold on the LGM G-2 springs....they served me WELL (2 KotHs wins in a row :burnout: ). If you do buy the Strano Springs, when you put in the rear springs make sure that you remove the aluim spacers between the bumpstops and chassis. Hope this helps out.
Val
PostPosted: Fri Nov 03, 2006 8:50 am
They're Eibach springs but I don't know their spring rates. I've got a set but I went linear 600fr and 150r w/ 3rd bilsteins. I liked the way Roy's handled and copied his setup to a degree. It's not bad at all and won't rattle your teeth out etc. How much of a drop are planning to do? I had to have my front bilsteins piston shortened since I go slammed and custom revalved. Don't worry about the SFC either Jerry. UNLESS you go BMR or SLP's they're stuff hangs something terrible. Go KBDD's or LG's and you'll never see the things like Val said.
 Post subject: Re: Strano Lowering Springs Question
PostPosted: Fri Nov 03, 2006 12:29 pm
I have the Konis on my car, lowered by the shocks front and did the heater hose mod on the rear (about 1" drop). The combination of the stock springs and the aftermarket shocks is firm but not uncomfortable at all. Of course I also have a 35mm Strano front swaybar that helps and KBDD SFCs.
PostPosted: Sat Nov 04, 2006 10:57 am
Thanks guys, I think I'll order them. I already got the Koni's from Sam but haven't installed them yet, so I think I'll order the springs and do it all at once. Hopefully it won't ride too bad. Guess I'll find out. I may have to try the AutoX next year just for grins.
PostPosted: Wed Nov 08, 2006 8:22 pm
Well, I ordered them so guess I have work to do. Anyone have suggestions on what kind of panhard rod to get. If I get one with rod ends, how bad are they about rattling. Suggestions appreciated.
PostPosted: Thu Nov 09, 2006 11:48 am
I have the Strano PHR with rod ends, and it rattles just a bit on bumpy roads... but only there...
PostPosted: Thu Nov 16, 2006 9:18 pm
Got my springs in and I have some good news from the German guys who want to lower their car. The springs are made by Vogtland to Sam's specs. They are TUV approved. The TUV sign is on the box. Hopefully I'll get them on this weekend.
Jerry
PostPosted: Fri Nov 17, 2006 8:10 am
The BMR adjustable panhard rod is a good one. I would get it with the poly bushings though. They also have grease fittings on them. I would not get the solid ends because they will make noise. I bought mine from Thunder Racing. It is adjustable in the center of the rod.
PostPosted: Fri Nov 17, 2006 8:52 am
Post some pic's when it's done.
PostPosted: Fri Nov 17, 2006 9:41 pm
I run solid rods on my entire car. It's all in the quality of the rod. Mine don't make a sqeak.
PostPosted: Fri Nov 17, 2006 9:42 pm
Will do. Hopefully I'll get them done tomorrow.
Users browsing this forum: Majestic-12 [Bot] and 87 guests
