It is currently Mon Aug 24, 2026 3:22 pm
 Post subject: 860 HP @ 7500 RPM - WARHAWK BLOCK
PostPosted: Thu Dec 21, 2006 6:33 pm
:shock:
http://www.ls1tech.com/forums/showthread.php?t=620614
The numbers; 440 cubic inches-4.185 x 4.000. 16.0-1 compression. A cam over .900 lift. Of course a great pair of E/T heads flowing 430 near max lift. Normally aspirated. Seven pulls, 860 HP @ 7500 RPM.
PostPosted: Fri Dec 22, 2006 8:43 am
SWEET!!!!!!!!!!!!!!!!!!
PostPosted: Fri Dec 22, 2006 10:50 am
16:1 compression, that's a high ratio. :o
PostPosted: Fri Dec 22, 2006 12:56 pm
Wow... remove the spark plugs and run Diesel :lol:
