Post subject: Cossie update Posted: Sat Mar 31, 2007 5:05 pm |
Well got the motormounts installed . That was a royal pain in the AZZ . Had to drop the oil filter and starter . Guess where the oil filter is? Directly above the starter . Yep you guessed it dumps right on the starter . In order to pull the starter you have to pull the filter . So there is no winning. So the mounts are in , oil filter on , and starter back in. Went to drain the pan and you guessed , the oil pan drain threads are stripped out. Thank goodnes for a over size self tapping oil pan plugged.
Got it all together and warmed up and took it fro a road test . There is quite some turbo lag until the boost comes on and then hold on . It was to the point of spinning all four tires on the wet pavement . Did find a weak half shaft that I must replace and I seen the engine temp was rising when in boost . Gotta check out what is up with that.
Garry
Post subject: Posted: Sat Mar 31, 2007 6:35 pm |
Sounds like some serious power you're putting out ... or very low traction
good to hear you're starting to get somewhere with it ...
Post subject: Posted: Sat Mar 31, 2007 6:40 pm |
TurboManiacal
Post subject: Posted: Sat Mar 31, 2007 6:49 pm |
Joined: Tue Sep 21, 2004 12:43 pm Posts: 963 Location: Mannheim
Roy wrote: It is probably the low traction part. Hopefully Iget it sorted here real soon.
I hope you don't.  This car is going to be mean at bitburg!
_________________ 2008 BMW 335xi
Post subject: Posted: Sat Mar 31, 2007 6:53 pm |
I have come to the conclusion that in order to beat quick nimble little cars . Is to have one also and have a little bit of driving skill. Well at least I got the car .
hotrodredneck
Post subject: Posted: Tue Apr 03, 2007 4:29 pm |
Joined: Fri Feb 03, 2006 8:12 pm Posts: 664 Location: Newport News, VA FT Eustis
congrats bro......maybe you should look into getting an oil filter relocation kit?????
Post subject: Posted: Tue Apr 03, 2007 6:53 pm |
hotrodredneck wrote: congrats bro......maybe you should look into getting an oil filter relocation kit?????
I am going to try a round plastic jug an cut the bottom out then slide the socket and filter thru the bottom and onto the filter.
jeejee
Post subject: Posted: Tue Apr 03, 2007 9:16 pm |
you could use a filter mount from an escort cossie as the filter is relocated with sort of a remote filter adapter.
not quite sure about the small car "if you can't beat them join them" theme, we had quite a though time on val's car
Post subject: Posted: Wed Apr 04, 2007 5:04 am |
I will keep an eye out for one .
My next problem I think Iam over boosting. It will boost to 2 Bar for approximately 15 secs and then cut back to about 1.3 to 14 bar.
I think 2bar is a little excessive especially not knowing what is in the engine, and how healthy the engine is .
jinstall
Post subject: Posted: Wed Apr 04, 2007 9:42 am |
Joined: Tue Jul 12, 2005 5:08 pm Posts: 942 Location: Fort Bliss, Texas
Damn Roy I have got to get in touch with Berdt, he can answer ANY question you have on the car. Suhe built his motor as well. I know he owns the 2 Jet gas stations in Wiesbaden. Teh one with the car wash by the PX and the one at Walmart on Mainzerstrasse. The weather is nice so he should be driving the Sierra with the Mov'it brakes. If not it will be the Focus RS or the Fiesta ST. Seems it is registered in his wifes name not Bernd's.
http://www.jet-tankstellen.de/tankstell ... l=&x=0&y=0
_________________ 2001 Ford Focus sleeping in Germany 04 Focus ST170 Clone in USA 2010 Renault Clio 1.2 16V in Germany 2013 Focus ST250 in the USA 1st car 77 Camaro Type Lt 5.0 auto
jinstall
Post subject: Posted: Wed Apr 04, 2007 11:45 am |
jeejee
Post subject: Posted: Wed Apr 04, 2007 12:46 pm |
2 bar is somewhat too much i think
could be that the wastegate isn't working at all
thats about all the boost what the little T3 can produce.
the reason it returns to 1,3-1.4 bar at higher rpm is that the turbocharger can produce anymore air
Post subject: Posted: Wed Apr 04, 2007 12:51 pm |
James if that was in the area around here I would go for it .
JeeJee I will look at the waste gate and the actuator tonight . IJust got my original Ford COSSIE manuals printed . SO now I can get some trouble shooting done.
Post subject: Posted: Wed Apr 04, 2007 7:43 pm |
Well the waste gate is okay it actuates . The rubber signal line from the compressor housing to the waste gate was cracked. So its repaired.
Checked the compressor bypass valve and the diaphram is ruptured. So while it was in boost it leaked pressure and at idle it had a vacuum leak at idle.
Has any seen a compressor bypass valve like the one in this picture . There are no markings on it and it is completely rebuildable.
| Attachments: |
Post subject: Posted: Wed Apr 04, 2007 7:56 pm |
Hey JeeJee
Have any Idea where these hoses connect to ?
The first picture is a hose that comes from the intake manifold I believe . I colored it red for clarification . Yes that is a waterbottle that the hose is going into now.
The second picture has a hose coming from a catch and going nowhere.
| Attachments: |
jeejee
Post subject: Posted: Wed Apr 04, 2007 9:59 pm |
the red hose from the intake manifold as you say actually comes from below the intake there is a hole that leads to the crankcase.
normally this then goes into a small seperator allso beneath the intake manifold
then it goes to the airfilter.
BUT with modified engines the crankcase pressure becomes a lot higher and as a result there will be blown a lot of oil into the airfilter
so then a hose will go from the small seperator to a large seperator ( the steel box in the passengerside of the engineroom)
along with 1 -2 hoses from the valvecover
so the hose that now is in the bottle will actually need to go to the steel large seperator (sec. picture)
but i can't see a vent to athmosphere at the top of the steel seperator you have.
that is ABSOLUTE nessesary !
without it you will blow all oil seals in the engine in notime..
can you make a better picture from the separator in the second picture ?
Joeri
Post subject: Posted: Thu Apr 05, 2007 5:20 am |
jinstall
Post subject: Posted: Thu Apr 05, 2007 7:50 am |
Roy did you get ahold of Berndt?
Post subject: Posted: Thu Apr 05, 2007 8:08 am |
jinstall
Post subject: Posted: Thu Apr 05, 2007 8:48 am |
Users browsing this forum: No registered users and 6 guests |
