It is currently Tue Aug 25, 2026 1:21 am
 Post subject: No fuel
PostPosted: Fri May 18, 2007 7:18 pm
The damn fuel pump isn't coming on I checked the fuses and the relay's there all good. Any ideas?
PostPosted: Fri May 18, 2007 7:30 pm
You check your VATS?
PostPosted: Fri May 18, 2007 7:51 pm
Would that stop the fuel pump from comin on? not even the gas gauge work's
PostPosted: Fri May 18, 2007 9:02 pm
does your car have a fuel cuttoff relay like in the stangs?....in the newer stangs they are in the rear...trunk, hatch, whatever....just a thought
PostPosted: Fri May 18, 2007 10:42 pm
You check the relay under the ds kick panel there is a relay there as well.
And yes VATS will shut fuel off.
PostPosted: Sat May 19, 2007 1:52 am
I have a dumb question, is there fuel in the car? Have you checked it lately. If the fuel guage is not working and you have no fuel to the motor then I would start there first. Then I would check the wiring by the fuel tank.
PostPosted: Sun May 20, 2007 8:04 pm
it has fuel the fuel pump is nit coming on when I turn the key. I haven't checked the wiring yet.
PostPosted: Sun May 20, 2007 8:16 pm
ok bro....just some stupid checks,
did you check the fuse for the fuel pump?
did you check to make sure there is fuel as asked above?
is there fuel in the system? ( can you check it like we can on stangs by the schrader valve on the fuel rail? (like a valve stem on a tire)
now some others... wher is the car? maybe I can come take a peek to see what I can find.
can u post a vid of how it sounds when you try to start it?
PostPosted: Mon May 21, 2007 7:30 am
First thing I did was listen to see if I could here the fuel pump prime when I turned the key on nothing so then I checked the fuel rail for fuel not even a drop so the I checked the fuse it was good the I switch the relay with the one for the horn, horn works so not the relay I havent checked the connector under the car yet. The car is in my garage down here at sembach.
PostPosted: Mon May 21, 2007 7:34 am
Replacing fuel pump sucks I reckon ... guess I will see how much when I check out my fuel tank for that leak I have ... :(
PostPosted: Mon May 21, 2007 8:21 am
Trap door baby less then a hour. :D
PostPosted: Mon May 21, 2007 3:31 pm
What I would do if you are good at wiring and plans is get the plan on the net and see which of the wires feeds the fuel out and with a battery charger you should be able to see if its the pump or the wiring.
Hope I could help you a bit.
PostPosted: Mon May 21, 2007 3:37 pm
I think I have some diagrams at home if you need anything ...
PostPosted: Wed May 23, 2007 12:10 pm
I am in the prosess of doing the trap door method to check the fiel pump. I will post pic's
PostPosted: Wed May 23, 2007 3:37 pm
It could possibly be a ground problem to. Maybe you dont have any ground going to the pump.
PostPosted: Wed May 23, 2007 3:47 pm
Thank's for calling I am going to check that right now.
