AndreasH
Post subject: Differential and Tuev Problems.. Posted: Sun Sep 30, 2001 8:01 pm |
Joined: Sat Sep 29, 2001 9:27 pm Posts: 17 Location: Jork, Niedersachsen, Germany
Hi,...
I hope that nobody has anything against my very bad english.
I test it...  )
I've a 99'Camaro Z28 and I have a pair Problems and
Questions about my car.
At first, since a half year I can hear a noise from the differential or any other thing at the rear side.
If the car drives without load, he's rolling, and I
drives small curves, it was a metallical "knocking" sound.
Under load, I hear no noises, no "knocking".
The Car has 3 Years Guarantee in Germany, also until January
2003. The very bad GM-(OPEL) Repair Workshops in Hamburg
don't find the Failure.. One old GM People there said, that
he Know about this error, but there was no Idea by GM to
remove it at a long time.
I Think the Differential is defect... but the Workshop won't
be change it .
The Second Problem, is a Question...
I am searching for any Styling things for my car.
A VA- 4-barEnd Exhaust/BackCat System (Borla or anything else?)
Then I'am interesting on a Ground effect Kit AND
the car should become smaller springs.. I mean it looks
like a LandRover
The Problem is, that i don't know, what says the German TUEV!???
I see that the most Members come from Germany...
(warum schreibt hier denn keiner in Deutsch??? zumindest teilweise??;( )?
Any Members have many modifications on his car... all things with TUEV??? Who can Help me, what is allowed, was makes Prolems?? Was is with a new Exhaust System?? Has it more Power? (the US-Modells have more PS than the European)
What is with the Car Guarantee if I make any Modification on my car??
Thanks...
_________________ --
Andreas
99' Camaro Z28
JackZ28
Post subject: Posted: Sun Sep 30, 2001 8:33 pm |
Garry can probably answer your question about the Tuev best, and I don't know about the differential, but I'm sure someone will help you. Tuev sucks, 'cause they don't let you do so much. Email Garry, and ask him. He is German, and has a lot of answers!!
IROC
Post subject: Posted: Sun Sep 30, 2001 8:39 pm |
Joined: Sat Aug 04, 2001 12:41 pm Posts: 570 Location: Nuremberg, Germany
Yep, thats right TUEV regulations really suck... they sometimes won´t even allow you an aftermarket catback...
JackZ28
Post subject: Posted: Sun Sep 30, 2001 9:15 pm |
Garry
Post subject: Posted: Sun Sep 30, 2001 9:33 pm |
Quote: I am searching for any Styling things for my car. A VA- 4-barEnd Exhaust/BackCat System (Borla or anything else?) Then I'am interesting on a Ground effect Kit AND the car should become smaller springs.. I mean it looks like a LandRover  The Problem is, that i don't know, what says the German TUEV!??? Good question - I doubt they should have anything against ground effects, may want to watch out when combining them with lowering set ... anyway, the exhaust I see a potential problem ... german TÜV is pretty restrictive when it comes to noise ... even nice sounding nice as a V8 is producing ..  I've checked other boards before, and to my knowledge, there is no muffler system that has an ABE, so you will have to have a "Einzelabnahme" - check with TÜV before getting anything - they should be able to tell you what dB level your car may have ... anyway, I doubt that any system like Borla, Corsa or SLP loudmouth will stay below that level ... Quote: Was is with a new Exhaust System?? Has it more Power? (the US-Modells have more PS than the European) Depending on the exhaust, you may gain some hp, but not too many ... Quote: What is with the Car Guarantee if I make any Modification on my car??
At least in the states, anything you don't change will still be under waranty ... no telling on how the german Opel dealers handle it ...
Hawk
Post subject: Posted: Sun Sep 30, 2001 9:43 pm |
TUV yuuuck. The knocking sound is the clutches in the rear diff sliping when you turn. I am asuming you have a limited slip diff? My 98 Z28 did it it was not as loud as you are discribing though but was annoying. As far as mods for Ha Pees do the not so obvious things like cut out the MAF bore the throttle body, underdrive pullies, hypertech power program w/powerstat and maybe a filter with a LS6 intake will get you 40 or so Ha Pees and TUV will have no Idea. The Polezei have this thing about noise.I am sure you could get a stock american exhaust from someone in the club for a little nothing. I also I hear they put the six cylinder exhaust on your car so unchoke it would be 10 more Ha Pees. But you need to talk to Gary he is the TUV expert of the club.
Garry
Post subject: Posted: Sun Sep 30, 2001 9:50 pm |
Quote: But you need to talk to Gary he is the TUV expert of the club.
P@ssed off by TÜV, yes, but expert? NOT ... good thing they will never get to look at the 79 ...  Guess the trip to Sembach will probably be the last time the car sees open roads ...  If I get the parts I need from Glen or Robin this week, that is ...
JackZ28
Post subject: Posted: Mon Oct 01, 2001 6:03 am |
Quote: good thing they will never get to look at the 79
What do you mean by that?? Can they not inspect it, or are you just doing something temporary, for the race???
Dark Angel
Post subject: Posted: Mon Oct 01, 2001 6:16 am |
Joined: Sun Aug 26, 2001 4:51 pm Posts: 681 Location: RAF Lakenheath, UK
The noise from the rear, like Hawk said is the differential. My '01 does the same damn thing. Drives me up the wall sometimes. I even put the Redline lube and GM additive in it. Still does it.
_________________ Dark Angel is ready to rumble!!!!
Garry
Post subject: Posted: Mon Oct 01, 2001 7:38 am |
Quote: What do you mean by that?? Can they not inspect it, or are you just doing something temporary, for the race???
If the car is not being registered for regular street use, it is not being checked by TÜV ... last time TÜV seen it was in '98 I think ... maybe even '96 ... it had red 07 plates since '99 or so ...
JackZ28
Post subject: Posted: Mon Oct 01, 2001 10:10 am |
Garry
Post subject: Posted: Mon Oct 01, 2001 10:26 am |
Quote: Hmm, very interesting! So if you have a car that you use strictly for racing, you don't need any kind of inspection??
Yup - no plate, no hazzle ...  And if it's halfway streetable, I can alsways use a red plate ... anyway, if it's light enough, I'll use a trailer to pull it with the BMW, that way I don't have to pay the fuel ...  And at 12mpg, the '79 isn't that conservative at using fuel ...  (wonder how much I'll be using on the way down next weekend ...)
Hawk
Post subject: Posted: Mon Oct 01, 2001 9:28 pm |
You could throw a set of stage II heads and small Comp cam 500 lift 114LSA and 220dur@50 and reprogram the computer in that car good for 50-70 Ha Pees. The TUV police would never know!!!
99taws6
Post subject: Posted: Mon Oct 01, 2001 9:31 pm |
Quote: You could throw a set of stage II heads and small Comp cam 500 lift 114LSA and 220dur@50 and reprogram the computer in that car good for 50-70 Ha Pees. The TUV police would never know!!!
You could put a V-Tech sticker on the car good for what like 75-100 or so... They would never know...
Hawk
Post subject: Posted: Mon Oct 01, 2001 9:39 pm |
Whats up with V-tech? Yes I agree you need to watch out for them Euro stickers. I seen this sticker one time and he said it was worth 300 Ha Pees. Stickers equal speed in europe!!! I have no Idea what it was but it was ugly.
99taws6
Post subject: Posted: Mon Oct 01, 2001 9:45 pm |
Quote: Whats up with V-tech? Yes I agree you need to watch out for them Euro stickers. I seen this sticker one time and he said it was worth 300 Ha Pees. Stickers equal speed in europe!!! I have no Idea what it was but it was ugly.
If we ever get those fbodyeupe stickers we will be dangerous.....
Hawk
Post subject: Posted: Mon Oct 01, 2001 9:48 pm |
400 Ha Pees is what I will say when a German asks me.
Gunnar
Post subject: Posted: Fri Oct 05, 2001 6:10 am |
Joined: Sat Aug 18, 2001 8:35 am Posts: 220 Location: Germany
Fuer Andreas in Deutsch!
Es gibt m.W. zwei Tuner in Deutschland, die viel fuer Dich tun koennen:
RED Motorsport GmbH (02 02) 7 48 42-0
42327 Wuppertal, Industriestr. 33
Geiger Performance GmbH
Truderingstr. 265
81825 München
Tel. 089 / 4271640 Fax 089 / 42716410
Spezialist für US-Cars
http://www.geiger-performance.de
Dann bin ich bei meiner Suche nach einem Z28 bei mobile.de ueber einen gestolpert (schau selbst, es sind Bilder von der 4-Rohr-Anlage dabei!), der leider leider nur Automatik hatte, aber siehe selbst und ruf mal dort an!
Daten:
4.800 km, 211 kW (287 PS), EZ: 07/99, TÜV: 07/02, AU: 07/02, silber-metallic
Besonderheiten:
Automatik, Jahreswagen, Klimaanlage,
Beschreibung:
Überrollkäfig, 18" Alufelgen, Tiefer, König Sportsitze, Soundsystem mit CD Wechsler, Borla Auspuff (Top Sound), 1. Hand, Airbag, ABS, el. Fenster, el. Spiegel, . .. Neupreis:78. 940, - DM Ihr Ansprechpartner Herr Salehi
Händler:
Autohaus Werkmeister
Diesel Strasse 20
D-54634 Bitburg
Tel.: +49 - (0)6561 / 91630
Fax: +49 - (0)6561 / 91631
eMail: ah-werkmeister@mobile.de
Besuchen Sie uns auch unter http://www.mobile.de/AH-Werkmeister
Ciao!
Gunnar
_________________ Until November 2004 I had a:
AndreasH
Post subject: Posted: Tue Oct 23, 2001 8:18 pm |
Hi all,...
Quote: At first, since a half year I can hear a noise from the differential or any other thing at the rear side.
Only a Info,...
Today I was in Hamburg at the GM-Service.
The Service-Chief (Mr. Eder) has made a Test driving
with this car because the knocking sound.
After it, he want to order a completely new Rear Axle
include a new Diferential... on Guarantee...
I hope this help...
AndreasH
Garry
Post subject: Posted: Tue Oct 23, 2001 8:47 pm |
Quote: After it, he want to order a completely new Rear Axle include a new Diferential... on Guarantee...
Now that's good news! Hope it solves your problems! But be prepared for a long wait ... took them (Opel at Hersfeld) over 3 months to get some of the parts in for mine ...
Users browsing this forum: No registered users and 25 guests |
