It is currently Wed Jun 24, 2026 4:27 pm
 Post subject: swap 2L8-->3L1
PostPosted: Sat Jul 14, 2007 12:19 pm
what is the difference between the 2L8 and the 3L1?
i have buy a 88 firebird but is engine have a problem! a friend give me a 3L1 with a very good condition but what is the difference of this engines? :roll:
PostPosted: Sat Jul 14, 2007 1:39 pm
Sorry I am not familiar with the v6
PostPosted: Sat Jul 14, 2007 4:44 pm
ok no problem but i do get out the auto trans too because i don't can get out only the engine :cry:
PostPosted: Mon Jul 16, 2007 11:49 pm
Approximately 300cm³ :?:
:lol:
http://www.MuscleCarsAndCo.com
PostPosted: Tue Jul 17, 2007 5:54 am
:lol: :lol:
PostPosted: Tue Jul 17, 2007 6:06 am
I know there is a member doing a 3.4l to LT1. That may be a better and more viable swapp.
PostPosted: Tue Jul 17, 2007 8:18 am
Not very clear, but all changes are listed ;)
http://60degreev6.com/view.php?pg=familytree
Basically the 2.8l, 3.1l, 3.4l is the same engine, just with different bore/stroke/heads but the same block.
What year is the 2.8 and the 3.1?
3.4 to LT1 is like ripping out everything, buying a V8 seems a bit easier.
PostPosted: Tue Jul 17, 2007 8:51 am
I would even drop a 4,3 V6 in it before another 3,1-3,4 just more potential and its a 90 degree V6 not a 60 degree.
PostPosted: Tue Jul 17, 2007 11:42 am
Dropping in a 4.3 is as much work as putting in a LT1, if not even more as it was never meant to be in that car.
And what make's a 90° V6 better than a 60° V6, just out of interest? :?
PostPosted: Tue Jul 17, 2007 4:24 pm
Well lets put it this way the 4,3 v6 is an unbeatable engine (great on power versus wheight and never breaks runs forever) The 3,4 is known for the intake leak(interbnal) problem and it wont turn to many rpm. Also more clearance from top to bottom but wider. Also I heard a 4,3 with dual 40 flowmaster and it sounds mor like a V8. About the 60 and 90 degree I just prefer the 90 degrees better.
PostPosted: Tue Jul 17, 2007 8:19 pm
But what's the difference, just the wideness?
PostPosted: Tue Jul 17, 2007 8:30 pm
Well there is a 90degree angle between the two cylinder banks or a 60 degree angle. in a boxer engine its 180 degrees thats why the boxer is so wide. It like straight.
PostPosted: Tue Jul 17, 2007 10:07 pm
the year of my 2L8 is the year of the car, 1988 but the year of the 3L1 is 1991. i don't install a V8 for the moment because i must make the french paper for the car, he's going to the luxembourg but in 3/4 years , a conversion for a ls1 or a ls6 is not impossible :D
for the moment i would like a car for cruising, juste cruising, i have a 74 camaro in restoration :wink:
PostPosted: Wed Jul 18, 2007 8:16 am
YEah then just swap the 3,1 in it. Youll figure it out!!!
PostPosted: Thu Sep 27, 2007 4:10 pm
I found a thread on thirdgen.org saying the swap should be easy. The thread is mostly useless, so I won't link it.
You could keep your intake and other parts to keep it simple.
PostPosted: Thu Sep 27, 2007 4:20 pm
I found a better thread, I haven't read it all but it seems to cover a lot.
http://www.thirdgen.org/techboard/engin ... 2-8-a.html
PostPosted: Thu Sep 27, 2007 5:30 pm
why bother if you plan on putting an LSx in 9 months later?
PostPosted: Thu Sep 27, 2007 8:01 pm
I have a brand new 4.3 setup for a big turbo sitting in my garge collecting dust since December.
 Post subject: Re: swap 2L8-->3L1
PostPosted: Sun Feb 03, 2008 1:11 pm
hi! i have found a ecm for install my 3L1, i do finish my work for cruising!!! say you later with pics!!!
