It is currently Tue Aug 25, 2026 12:39 am
 Post subject: Conversion to European Spec
PostPosted: Wed Jul 05, 2006 8:35 am
Does anyone know what needs to be done to convert a 1991 Camaro to Euro spec or where to go near Stuttgart to have it done?
Thanks,
Dan
 Post subject: why
PostPosted: Thu Jul 06, 2006 9:00 am
why do you need to convert it just leve it be thier is ono reason to do that
I.Y.A.A.Y.A.S. (if you ain't ammo you ain't sh@t)
PostPosted: Thu Jul 06, 2006 10:56 am
I love how Ammo guys are so happy to be Ammo.
How about "Spell check" brotha?
 Post subject: LOL
PostPosted: Thu Jul 06, 2006 11:19 am
heay mann just typeing you could reed it wright LOL
PostPosted: Thu Jul 06, 2006 12:45 pm
There is a reason to do it, trust me I wouldn't waste my money.
 Post subject: US TO GERMAN SPECS?
PostPosted: Wed Aug 02, 2006 6:06 pm
JUST CURIOUS, BUT WHAT IS YOUR REASONING FOR CONVERTING IT?
 Post subject: Re: US TO GERMAN SPECS?
PostPosted: Thu Aug 03, 2006 9:06 am
To give it to my step-son.
PostPosted: Thu Aug 03, 2006 11:55 am
I mean, why would you do that if the u.s spec is held to a higher standard than a german spec? It already has km's on the speedometer. It does'nt have to be german specs to be in germany or to be put in the german system. As far as I know, they dont make conversion kits for any car to go from u.s to german. Also, you will have to change the winshield and the back lights. I just wanted to know why you would do all of that un-neccessary stuff if you dont have to.
PostPosted: Fri Aug 31, 2007 1:37 pm
Hey!
If his stepson is either German or on the German system, some things have to be changed. What I did with my '92 Z28 is go by the TUV, make an appt to see (there's 1 @ every TUV) the guy who's resp for imports. He'll check the car & tell you EXACTLY what needs to be done. In my case, it need the VIN engraved in the eng compartment, rear fog lite w/lighted switch & low beams w/ integrated turn signals so they can be separated from the side running lights. THAT'S ALL!!!
R.
PostPosted: Fri Aug 31, 2007 1:38 pm
Hey!
R.
PostPosted: Fri Aug 31, 2007 4:09 pm
It really depends pretty much on the TÜV guy (believe me, i learned this the hard way), so go to the next TÜV place, ask what needs to be changed, if it seems to be too much, try a different place. THEN start the conversion and do only what he told you, everything else is a waste of time and money...
PostPosted: Mon Sep 03, 2007 10:48 am
:ok:
Aaaaamen!
8) Exactly!!!
R.
