It is currently Mon Dec 15, 2025 7:36 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
I would have posted this the other day but I was to ticked off. I was driving to work on wensday and I got into a race with a 2000 mustang GT. I one the race by alot hands down. My exit came up so I slowed down I stepped on the clutch and the car just
none 0%  0%  [ 0 ]
Total votes : 0
PostPosted: Sun Sep 30, 2001 10:58 am
Sounds like they suck. Are they expensive parts to replace? Where are they on the engine? The typical distributor spot on a small block or somewhere else?
PostPosted: Sun Sep 30, 2001 11:01 am
It is located up front on the crank under the water pump. I like the ls1 ignition system better.
PostPosted: Sun Sep 30, 2001 11:06 am
OK, so it's basically a crank trigger.
PostPosted: Mon Oct 01, 2001 9:50 pm
Did you get it figured out yet? Race day is 5 and a wake up.
 Post subject: v8speed
PostPosted: Tue Oct 02, 2001 7:31 pm
The Opti is located right behind and bellow the water pump and it's above the crank hub. It's easy to replace it just takes a little time.
 Post subject: Bruce
PostPosted: Tue Oct 02, 2001 7:45 pm
To be honest with you I really havn't did anything but start it. I started it yesterday there were no unusual noises or anything. I didn't let it run that long so I still had oil pressure. I have narrowed it down to a few different things.
1. definate spark plugs
2. maybe the oil sending unit it looks like it has a bad wire.
I hope I get it running before race day I've been looking forward to racing for a while now. I'm getting kinda annoyed with this whole car down situation.
GEORGE OR ANYONE WHO KNOWS????????
You mentioned the oil screen may be clogged when preassure builds up. My ??? is where is it located I really really really hope you don't say in between the oil pan and the crank!!!!! If it is I'll see you guys next year.
PostPosted: Tue Oct 02, 2001 8:13 pm
Ryan I am not sure on the LT1's.. On a SBC it is under the pan...
 Post subject: george
PostPosted: Tue Oct 02, 2001 8:36 pm
I knew you were going to say it was under the pan. I pretty much knew it was under there the whole time I was just praying it wasn't. If it is under the pan and it's clogged I have two options do the engine flush treatment. Or wait till this winter when I rebuild anyways. At this point I would have to say this winter I don't want to lift the engine 6 inches just to get the pan out. I already replaced the gasket and that was a pain in the Azz. They don't make these cars easy. Good info though Do you think an engine flush system would work??????
 Post subject: ####
PostPosted: Tue Oct 02, 2001 11:30 pm
Ryan, give me a call 06313509767, I have to pick your brain for some info, thanx, Dave Vautier
 Post subject: Hey dave V.
PostPosted: Wed Oct 03, 2001 1:35 am
Hey are you working tonight or are you at home. I just got back on and it's 0230 in the morning so I don't want to call you if your at home sleeping. If you are at work just respond back to this and I'll give you a call tonight. Talk to you later Ryan.
 Post subject: It's pretty bad
PostPosted: Wed Oct 03, 2001 1:39 am
That the only way I can get the topic folder to burn is to break my car!!!!lol. I do appreciate everyone's info that's the one thing I like about this board. When you can't figure something out someone else already has.
PostPosted: Wed Oct 03, 2001 5:12 am
I hope you are up for the race?
