It is currently Sun Aug 23, 2026 11:56 pm
 Post subject: Bilstein springs? Need infos!
PostPosted: Sat Feb 23, 2008 1:10 pm
Hello, i have a set of Bilstein springs that came from a Z28 and near brand new!
I have no infos about this bilstein springs.
Is this kit from the Bilstein bts kit or any stock GM Bilstein spings from SLP or LE1? Are this lowering or stock high springs?
The springs have this numbers:
Bilstein 199001 + 199002
Need help to identify the springs!
 Post subject: Re: Bilstein springs? Need infos!
PostPosted: Sat Feb 23, 2008 6:03 pm
The 001 is the front set. 002 is the back set. These are after market not factory, not BTS, Not 1LE . Probalby not SP since you can buy them directly from Bilstein for around 80 dollars a pair.
PostPosted: Sat Feb 23, 2008 6:14 pm
OK, thanks! I see on bilstein.com the springs. That is the stock high? But with progressive rate , i think.
PostPosted: Sat Feb 23, 2008 8:02 pm
BTW Bilstein does not make springs, H&R does.
BTW H&R does not make dampeners, Bilstein does.
They work together and use each others parts.
PostPosted: Sat Feb 23, 2008 8:44 pm
I heard that also James
PostPosted: Sat Feb 23, 2008 9:45 pm
Dramland, PM'd you.
PostPosted: Sun Feb 24, 2008 8:11 pm
I asked at Essen back in 2000 and also again with my contact at H&R Germany.
Users browsing this forum: No registered users and 24 guests
