It is currently Tue Oct 20, 2026 2:21 am
Post new topic Reply to topic  [ 76 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Just got back from the inspection place again.......
PostPosted: Wed Aug 27, 2008 3:18 pm
Not only is it too low now but the emergency brake doesn't stop strong enough. hahaha Jesus Christ, these guys really need to get their "He said POOP" together. They didn't even check the emergency brake last time. Also I asked them where exactly it says how high the vehicle has to be and they pulled out USAEUR reg 190-1 app C. In the body section it does say 11cm for all metal parts of the car. I get back to my office and look for the reg online to make sure it was 11cm and in the same reg on the internet it doesn't say anything about height in the body section. I am thinking they are using the old reg at the vehicle inspection place that the one on the internet says it supersedes. I tried to call them and find out which version they were using but they were closed for the day. I am going to call them tomorrow and ask them about it. I'm sure they'll just say something about "well German reg says.. and we go by that" but it's worth a shot. Fixing this thing as it sits would just require some exhaust work and removing the subframe connectors so I'm thinking about $400 but I really don't want to spend any money right now.
2008 Corvette Z51 M6
Black
2000 Camaro SS Conv. M6
*Sold*
 Post subject: Re: Just got back from the inspection place again.......
PostPosted: Wed Aug 27, 2008 3:19 pm
haha, he said POOP
Black
*Sold*
PostPosted: Wed Aug 27, 2008 6:51 pm
Well you should definitely call them back to verify which reg they are using, it is worth a shot. Let us know what they say.
01 TA-M6-Blue
PostPosted: Wed Aug 27, 2008 7:56 pm
Fight the power! What springs did you say you had on there?
Also, was this on a re-inspection? Did you have the previous inspecction documents? If so, they are to only inspect what was supposed to be repaired from the last one.
One more thing, 11 CM is just over 4-1/4 inches. Is your car really that low? I would get the cats replaced with a pipe and leave the subframe connectors where they are. I have BMR boxed with no problem.
PostPosted: Wed Aug 27, 2008 9:24 pm
I have the strano springs on there. The car itself isn't that low at all. It's the exhaust that is making me fail and since they got the 11 cm block under there they noticed it hits the subframe connectors too. I need the exhaust to come up about an inch. The idiots that welded it all together back in the states didn't even try to route the exhaust through the indentions on the bottom of the car so it is really low. The QTP catted y just isn't thought out to well to begin with but the exhaust shop didn't do anything to make it fit better. They actually made it worse I think. They have the part with the cat on it coming off of the header angled down. :? Oh and I did have the previous inspection documents but the damn german guy looked at them like he didn't know what the "he said fornicate" they were, handed them to the military guy and then proceeded to drive the car around the lot doing the brake check.
Black
*Sold*
PostPosted: Wed Aug 27, 2008 9:52 pm
Was it expired?
4 DEC 06 Army In Europe Reg 190-1
"C-3, c. A previously inspected vehicle will be re-inspected only for the deficiencies listed on the validated AE Form 190-1H or AE Form 190-1I."
PostPosted: Wed Aug 27, 2008 10:01 pm
....and where did you find the height restriction? I know it is in there, but I cannot find it.
PostPosted: Thu Aug 28, 2008 5:38 am
Nope it wasn't expired. They just don't know what they're doing. Oh and about the height requirement, the guy showed me where it said 11cm for metal parts in his copy of 190-1 but then when I got back and looked on the internet at what I would assume to be the most up to date version that supersedes all other versions there's nothing in there. That's exactly why I'm calling them when I get into work and asking them where exactly it says the height requirement. I bet you money they are using the old version of the reg. I was bsing with one of the guys that work there while they were looking at my car and he said he had never heard of there being a height requirement.
Black
*Sold*
PostPosted: Thu Aug 28, 2008 7:17 am
I don't think German TÜV even has such a thing ... 11cm appears to be quite a bit though ... guess I'd fail with mine, too due to the location of the left cat ...
PostPosted: Thu Aug 28, 2008 8:27 am
Exactly, we don't have that (contrary to Austria).
PostPosted: Thu Aug 28, 2008 8:56 am
Well I called them about it and they said the one on the internet is old and has been replaced by the one they have. Looks like there's no way around getting the exhaust redone.
Black
*Sold*
PostPosted: Thu Aug 28, 2008 11:06 am
Well, that should be a quick fix ...
PostPosted: Thu Aug 28, 2008 2:26 pm
Did they say what the date was? They should be able to give you the date of the reg and the paragraph of the requirement.
PostPosted: Thu Aug 28, 2008 4:06 pm
This the most current version from USAREUR/USAFE 4 Dec 06.http://www.fbodyeurope.org/gallery/8_aer190-1.pdf
PostPosted: Thu Aug 28, 2008 5:54 pm
Thats what I have also.
PostPosted: Sat Aug 30, 2008 10:48 am
Yeah, that's the one that is online but not the one they have at the inspection place. I didn't get a chance to check the date on the one at the inspection place but when I called he assured me that it was the most recent one. He said it has already been brought up and taken up the chain and has been a big problem with that one not posted on the internet. It has been like that for months though. I don't see how just getting it posted on the internet can be such a problem. Is anyone heading over to the pulaski vehicle inspection next week? If so can you ask to see their reg and check the date on it? I got under my car and while the exhaust does hang too low there is no way I can get everything up 11cm unless I install different springs. My headers are about 10cm off the ground!!
Black
*Sold*
PostPosted: Sat Aug 30, 2008 5:50 pm
They make rubber spacers to raise the car by the coil springs. I would buy a set and install them in the car, get it inspected and let her go. http://www.jcwhitney.com/Coil-Springs/G ... _10101.jcw
PostPosted: Sat Aug 30, 2008 7:59 pm
I tried the rubber spacers. They didn't raise the car much at all. For the front ones to work properly I think you would have to take the strut apart and that's more work then I am willing to do. Someone came and looked at the car today and I think they are definitly going to buy it as soon as I get the title in the mail. He said he will just install stock springs so that should fix the low exhaust problem. I'm going to miss her but it will be nice paying off my credit cards.
Black
*Sold*
PostPosted: Sat Aug 30, 2008 9:13 pm
:( At least let him know about FBE ... or is it someone we already know?
PostPosted: Sat Aug 30, 2008 11:46 pm
This is so frustrating to me man. If you had to sell then you had to do what is vest for you. Its the freakin inspection crap that they keep adding. There is absolutly no one fighting for the good to regulate their BS.
Is the car staying in the area?
