It is currently Mon Aug 24, 2026 2:05 pm
 Post subject: Trans Shop???
PostPosted: Fri Apr 03, 2009 9:08 pm
dose any one know of a place to get an automatic (700r4/4l60) rebuilt?
1993 Z28;A4,.008shavedheads,Borla Adj catback,CAI,3.73 gears,Trick flow Elbow,Taylor 8.2 wires,NGK plugs,Pacesetter,UMI brackets,Spohn LCA, Spohn panhard,ZR1's
http://www.fquick.com/towshen
 Post subject: Re: Trans Shop???
PostPosted: Fri Apr 03, 2009 9:31 pm
I can check with the place that did my motor...
PostPosted: Sat Apr 04, 2009 7:57 am
OK, got a message back, they do ... give 'em a call and let them know what you want done, just plain rebuild or "improvements" ;)
http://www.danys-garage.de/
Phone: 06231 2172
Ask for Dany or Andy ...
PostPosted: Sat Apr 04, 2009 9:21 am
Here is another place just also http://www.automatik-getriebe-center.de/
Automatik-Getriebe-Center Jens Winkler e.K.
Bahnhofstraße 15
88048 Friedrichshafen/Kluftern
Tel.: +49 (0) 7544/ 959 958
Fax: +49 (0) 7544/ 959 960
E-Mail: info@automatik-getriebe-center.de
PostPosted: Sat Apr 04, 2009 1:16 pm
the other day was the first time i got the car out on the Autobahn since i pulled it out of storage and put in the chip from PCMforless and it was acting kinda funny! crusing at 90mph i was sitting at about 3000rpm, now i cant remember if that is normal or if my TQ is messing up on me. car will still hit 140 no problem.
issue 2, after driving for a bit (till the car is warm) the trans will start to hold shifts mainly 1 to 2 shift. and if i am crusing down the road (50-60mph) and i floor it to pass the car will try to downshift into 2ed and redline then hop in to 3ed.
all of it is kinds hard to explain but any in put will help! or could these problems be caused by the new tune? i'm really hoping its not the trans taking a poop!
thats what the trans is doing, it should not have any thing to do with the tune since the trans is not an electronic one. but it dose have 170,000miles on it.
and how far are them places from bitburg/spang?
PostPosted: Sat Apr 04, 2009 2:56 pm
From what you are saying , your tranny is normal. Albeit you have 170 thousand miles on it.
Does the fluid smell burnt?
PostPosted: Sat Apr 04, 2009 5:42 pm
fluid seams fine....i have a new filter/pick up im going to put in along with a flush, but just have not had time to do it yet. and the trans has not been serviced since before i bought the car in 05.
the issue #2 up there is what is bugging me the most. there are times it will hold 1st till 4000+ rpm and this is normal acceleration.
PostPosted: Sat Apr 04, 2009 8:10 pm
Have you checked with Mark in Binsfield to see if he could do the tranny rebuild/upgrade for you?
01 TA-M6-Blue
PostPosted: Sat Apr 04, 2009 10:42 pm
do you have any contact info for him?
PostPosted: Sun Apr 05, 2009 5:15 am
You,ve got the fabled 93. Swapped the stock chip back in. It takes less than 2 minutes to do and you will be able to confirm if there is even an issue. PCM4less probably did some transmission tuning that just is not working with your car.
PostPosted: Sun Apr 05, 2009 7:41 am
Mark's number is 0657596066. If you go up there or call up there be sure to talk to Mark. There is another guy that works up there that can speak really good english, but I can't remember his name right now. If you can't find it let me know, I'll let you follow me out there. It's just a few minutes away from Spang.
Address is:
Werkstatt Zentrum Binsfield (Auto Service Center)
Industriestrasse 1-3, 54518 Binsfield
01 TA-M6-Blue
PostPosted: Tue Apr 07, 2009 5:12 pm
Address is:
you happen to know there hours? and have you had work done there? if so, is it good quality?
PostPosted: Tue Apr 07, 2009 5:41 pm
Yes I have dealt with them...they did the axle seal swap on my 12 bolt. I had heard great things about him before from a guy that had a bada$$ corvette (he left right after I got here). But no, I don't know their hours. I have been there till like 530 or 6 before. You could give them a shot, they do great work. Just drive down and talk to Mark or call him and see what they can do for you. I need to go down there, so if you want to go you can follow me down there.
01 TA-M6-Blue
PostPosted: Tue Apr 07, 2009 8:54 pm
thanks! im going to try to head down there tomorrow hopefully or at least give them a call...the trans is slowly getting worse! i know hear Klunking! :(
PostPosted: Wed Apr 08, 2009 3:59 am
Ouch, hopefully they can hook you up.
01 TA-M6-Blue
PostPosted: Thu Apr 23, 2009 6:36 pm
well so far so good with the place in Binsfeild! took my car in on monday to have them trouble shoot my trans and ended up being a dieing valve body resulting in lots of F'ed up hyd. pressures and slowly killing it. originally estimated around 1500Euro for a rebuild, but called mark today and he was saying he has come across a used but good 700R4! and it will probably be much cheaper then getting mine rebuilt. so im hoping for the best!
PostPosted: Fri Apr 24, 2009 4:57 am
That's good news! I told you he could help you out.
**I saw you fly up behind me yesterday.
01 TA-M6-Blue
Users browsing this forum: No registered users and 20 guests
