a10beav
Post subject: Re: failed inspection Posted: Sun Apr 19, 2009 11:47 am |
Thanks for the info. I may try and tackle this, but I'm not sure how much I'll be able to use those regs.
Chevroletfreak
Post subject: Re: failed inspection Posted: Sun Apr 19, 2009 12:52 pm |
| No Life |
Johnny, I am well versed with the UASEUR reg. I am more than happy to help. Just let me know when/where and what you need.
ralliartist
Post subject: Re: failed inspection Posted: Mon Apr 20, 2009 12:43 am |
Joined: Wed Mar 18, 2009 6:04 pm Posts: 42 Location: Omaha, NE - Soon to be Spangdahlem!
Thanks for the info guys. Looks like I'll be getting my cutout removed. Sucks, but you gotta do what you gotta do. I guess I'll go ahead and replace my axle-back piping for flow also. My stock is 2.25 and from the axle forward is 2.5. So I'll replace the cutout with a pipe and the axle back and I should be good to go.
You guys have helped me out a lot. I can't wait to meet you all.
 Napa Get the Good Stuff
Fast GTO
Post subject: Re: failed inspection Posted: Wed Apr 22, 2009 10:04 pm |
Joined: Sun Sep 26, 2004 4:12 pm Posts: 404 Location: Schweinfurt Germany
Got a few questions about this since I might be on my way back.
1) Do they fail you if you have SFC's that clear 11cm? 2) Do you have to provide any inspection certificates for aftermarket shocks/springs? 3) Do they do emissions? 4) My understanding is that 96DB is the limit, at what RPM? 5) Do they fail you for a cage? 6) Do they fail you for having nitrous pipping run to the motor?
I'm willing to remove the cage, SFC's, and nitrous lines as well as get new mufflers but not so much in regards to getting the suspension certified (it is just stock replacement items).
I also wouldn't pass emissions but I do think I can get the stroker silent enough for the inspection.
Thanks.
_________________ 2003 Cobra Current Modifications: 2.2L KB (Race 20psi = 632rwhp / 592rwtq; Street 18psi = 626rwhp / 564rwtq) Full Bassani Exhaust AEM Meth Injection
hotrodredneck
Post subject: Re: failed inspection Posted: Thu Apr 23, 2009 4:30 am |
Joined: Fri Feb 03, 2006 8:12 pm Posts: 664 Location: Newport News, VA FT Eustis
no emissions, but the rest I cant be sure on....depends on where you go...go to either taylor barracks or Heidelberg
Chevroletfreak
Post subject: Re: failed inspection Posted: Thu Apr 23, 2009 4:35 am |
| No Life |
Fast GTO wrote: 1) Do they fail you if you have SFC's that clear 11cm? No. Fast GTO wrote: 2) Do you have to provide any inspection certificates for aftermarket shocks/springs? No. Fast GTO wrote: 3) Do they do emissions? Not yet, but there has been talk about starting it. Fast GTO wrote: 4) My understanding is that 96DB is the limit, at what RPM? The limit is 95dB at 1/2 the redline on your tachometer. Fast GTO wrote: 5) Do they fail you for a cage? I have not heard of this happening and do not know why they would. I am sure it would attract attention to make them look deeper into other things to fail though. Fast GTO wrote: 6) Do they fail you for having nitrous pipping run to the motor? I will have to look that one up, but I do not think so. Fast GTO wrote: I'm willing to remove the cage, SFC's, and nitrous lines as well as get new mufflers but not so much in regards to getting the suspension certified (it is just stock replacement items). I wouldn't change any major items until they tell you to. The consistency is not the best. Fast GTO wrote: I also wouldn't pass emissions but I do think I can get the stroker silent enough for the inspection.
Thanks. Nothing a bag and a half of steel wool won't fix
Fast GTO
Post subject: Re: failed inspection Posted: Thu Apr 23, 2009 10:33 am |
Is the steel wool trick actually working for people?
Chevroletfreak
Post subject: Re: failed inspection Posted: Thu Apr 23, 2009 12:40 pm |
| No Life |
Got me from 102 to 95dB!
Fast GTO
Post subject: Re: failed inspection Posted: Thu Apr 23, 2009 1:04 pm |
What if I pretend to hit the gas and make vroom vroom noises?
hotrodredneck
Post subject: Re: failed inspection Posted: Thu Apr 23, 2009 1:09 pm |
just make sure you put the steel wool so it doesn't come out when they rev it
Garry
Post subject: Re: failed inspection Posted: Thu Apr 23, 2009 1:35 pm |
Fast GTO wrote: What if I pretend to hit the gas and make vroom vroom noises?  I believe I read about one of the electric sports cars that had a sound generator mounted to simulate engine sounds
BenZ28
Post subject: Re: failed inspection Posted: Thu Apr 23, 2009 2:07 pm |
Yes, Brabus makes that for the Tesla.
ralliartist
Post subject: Re: failed inspection Posted: Fri Apr 24, 2009 5:04 am |
how do you get the steel wool out once you stuff it in there? Or does it matter? lol
Garry
Post subject: Re: failed inspection Posted: Fri Apr 24, 2009 5:23 am |
I guess it usually comes out by itself ...  ask Roy ...
Chevroletfreak
Post subject: Re: failed inspection Posted: Fri Apr 24, 2009 6:15 am |
| No Life |
I used one of the Dynomax(?) cones to hold it in.
theshadowed1
Post subject: Re: failed inspection Posted: Fri Apr 24, 2009 7:58 am |
Joined: Sun May 19, 2002 6:49 pm Posts: 118 Location: Minot North Dakota...Again!
The inspections plain and simple are BS. A cheap way to lower your decibles too would be to get a larger muffler. My original Cat-back muffler rusted after 6 yrs so i bought i think a hooker muffler which lowered the db noticeably. I am at the point where i am like f*ck them inspectors!!! I just put on my Strano springs and shocks on and if i have to i will register and deregister my car all year if i got to  !! F*ck these punkazz regulations!! My windows are messed up now because of the whole tint removal crap so now every crook and robber can just look down in my car!! Yeah i am a little up set about it  But i do know that the chubby bastard inspector at spang did say rubber spring boosters are legal as long as they do not fall out, so get the "U" shapred ones ....and man did he look for them even though i did not use them.
_________________ See it, Hear it, Feel it!!
Fast GTO
Post subject: Re: failed inspection Posted: Fri Apr 24, 2009 9:12 am |
If I use steel wool I'll shove them in the pipe just before the mufflers and hold them in with a steel filter/grate of some kind as well as put my cats back on...
Post subject: Re: failed inspection Posted: Fri Apr 24, 2009 4:24 pm |
ralliartist
Post subject: Re: failed inspection Posted: Mon Apr 27, 2009 12:45 am |
lol @ the possibilities of ghettoness. lol.
Fast GTO
Post subject: Re: failed inspection Posted: Fri May 01, 2009 8:50 pm |
Okay, just found out I am going to be heading back to Germany.
Really need to try and crack the code on this so I'm not screwed with a car I can't register.
If 11cm under body clearance and 95db is all I have to worry about then I can work with that. Last time I was there I was given a lot of crap about my other modifications and not having the proper documentation for suspension/brakes etc...
Users browsing this forum: No registered users and 33 guests |
