It is currently Mon Aug 24, 2026 7:56 am
 Post subject: Purchased TSP 1 3/4 headers / y-pipe and TSP rumbler catback
PostPosted: Wed Feb 13, 2013 6:11 am
Still here in Aghanistan for 2 weeks but Just purchased new exhaust system, will the stock tune be ok, if not will i need a tune? If so any recommendation for anyone close to Nuremberg/wurzberg that can do a tune? Thanks in advance guys
 Post subject: Re: Purchased TSP 1 3/4 headers / y-pipe and TSP rumbler cat
PostPosted: Wed Feb 13, 2013 9:48 am
Catback exhaust or also headers? No tune needed with just a catback exhaust system...
PostPosted: Wed Feb 13, 2013 11:43 am
TSP 1 3/4 headers, h pipe and cat back system will all be installed,
PostPosted: Sun Feb 17, 2013 1:37 pm
The tune will be fine. The car is a 1998, correct? I can only tune 1999 and newer. The LS cars respond to upping the rpm limiter and having just at 27-28 degrees of timing. Factory is set from 24-25 degrees. Have you considered upgrading to a newer ECU and Harness?
PostPosted: Mon Feb 18, 2013 6:09 am
I had not really thought about it. The only previous mod is the 3200 stall converter and level 3 performabuilt tranny, When i get back in 2 weeks ill install the TSP Headers y pipe and rumbler exhaust.
PostPosted: Mon Feb 18, 2013 8:02 am
I rechecked my supported vehicle list and HPtuners covers 98-02 F bodys.
PostPosted: Mon Feb 18, 2013 10:20 am
i am in ilisheim, so ill have to hit you up when i get back.
PostPosted: Mon Feb 18, 2013 10:47 am
No problem. I am heading to the field for three weeks beginning in early March. Be safe down there.
PostPosted: Mon Feb 18, 2013 12:09 pm
will do, Thanks
