It is currently Mon Aug 24, 2026 11:27 am
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Oct 18, 2001 10:37 am
Do your cars have enough power to do them burnouts?
PostPosted: Thu Oct 18, 2001 10:49 am
haha, i can do a burnout!
PostPosted: Thu Oct 18, 2001 11:36 am
You weren't around when I did 2 at nurnberg!! I think I can manage.
PostPosted: Thu Oct 18, 2001 11:37 am
Dave can definitely do a burnout!! ;)
PostPosted: Thu Oct 18, 2001 11:40 am
I'm pretty sure I can pull one off... I wish I could post the pic's Howie and I took two weeks ago from over here at Bitburg... Securtiy Forces said they could see the smoke all the way back at the base (we were at the old base) for all of you familiar with the area
PostPosted: Thu Oct 18, 2001 11:56 am
That's pretty impressive Scott!! There might be some use for you after all!!j/k:P
PostPosted: Thu Oct 18, 2001 1:56 pm
Heck Scott, you have an auto, so it should be cake for you!
PostPosted: Thu Oct 18, 2001 2:07 pm
Check it out I would be willing to take somebody on in a bornout contest.J/K
PostPosted: Thu Oct 18, 2001 2:39 pm
I put my money on Dave!!
PostPosted: Thu Oct 18, 2001 2:54 pm
I would take your money. LOL
PostPosted: Thu Oct 18, 2001 2:56 pm
I think they will both be good.
PostPosted: Thu Oct 18, 2001 3:06 pm
I would stop after the first tire popped. I would not want to destroy the wheel. If dave would go until both tires popped and make sparks fly he would win.
PostPosted: Thu Oct 18, 2001 5:48 pm
That's a little extreme there Bruce. I have gone until there was nothing but steel belts all the way across. That was before I came overseas.
PostPosted: Thu Oct 18, 2001 6:02 pm
I talked to Tony If you can catch him in the morning it is better. I think you should ask him what you should do? If it was me I would go with a 383 the clearances are not as crucial and a new block could be had for a little nothing and I bet the entire package is cheaper and stronger. The bang for the buck is 383. You have already picked up 33 CI the next 13 are weakening the block I know it can and has been done but you may want to drive it to my house sometime Abahn driving@ 100+ is hard on a engines. I want you to get what makes you happy I am just giving my .02 cents and I hope it helps.
PostPosted: Thu Oct 18, 2001 6:13 pm
He told you morning? I caught him finally and he said 5:00pm. If the 396 engine is that sensitive then forget about it. No seriously, they will both need clearancing, that is why I decided to let the experts build the short block. The cost is maybe $400 and that is machining and the 4-bolt conversion. I'm pretty certain I want the 396.
PostPosted: Thu Oct 18, 2001 11:56 pm
Then get it. Yes they both need clearancing just trying to keep you thinking!!!
PostPosted: Fri Oct 19, 2001 6:05 am
Gee thanks there Dave........
PostPosted: Fri Oct 19, 2001 8:28 am
I hope you can give me a run for my money next year.
PostPosted: Fri Oct 19, 2001 5:03 pm
You can garrauntee it!! Just so you know, short block is on order. Work will start mid November.
PostPosted: Fri Oct 19, 2001 9:29 pm
What you getting? Are you getting it through Tony? I know he will take care of you. I think he likes you for some reason?
