It is currently Mon Aug 24, 2026 11:46 pm
 Post subject: Over Rev
PostPosted: Sun Jul 31, 2005 7:09 pm
I think i got really lucky and got away with no damage, but I wanted to make sure. Just after the last turn on the N-ring, I was in 4th going for 5th gear and accidently hit 3rd instead. As soon as I felt the car jerk, I got back on the clutch quick. There are no strange sounds, no white smoke, nothing ovbiously wrong. Is there anything else I should check or look for.
PostPosted: Sun Jul 31, 2005 7:44 pm
If it starts ticking then you probably need to check the pushrods. It sounds like you didn't cause any damage though if it is still running fine.
PostPosted: Mon Aug 01, 2005 5:08 am
I did that in the same area a bout three years ago . I didn't think there was any damage either because it ran fine afterwards. That is until about one kilometer from Wiesbaden it picked up a dead cylinder .
Out come was one really bent pushrod and three minor bent ones.
PostPosted: Mon Aug 01, 2005 8:55 am
Gunnar had broken his engine with that. But i think, your engine is still ok.
PostPosted: Tue Aug 02, 2005 3:17 am
The were a few times when I was accelerating very strongly on dry pavement-
I smoked the tires going through second,
however I just went 500 to 800 RPM over redline,
as the tires smoked and heated up on full load...
...cold tires....
Motor is fine, stronger than ever...
1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
PostPosted: Tue Aug 02, 2005 9:32 pm
I had the same thing happening this past weekend, i missed gear and went to 1st gear instead of 3rd !
Luckily the PCM recognised the MASSIVE over revving and turned on the VTEC mode so i was able to let it rev even higher and make more power in the proces :D
PostPosted: Wed Aug 03, 2005 5:42 am
Sergio your killing me .Stop
