It is currently Mon Aug 24, 2026 2:30 pm
 Post subject: squeal like a pig
PostPosted: Mon Jun 17, 2002 8:09 am
I just put new Baer rotors and Hawk HPS pads on, got about 500 miles and now there squealing like a pig every time I brake slowly. Should I try rebeding the pads or is it a lost cause? Nothing worse than a $32,000 car and having it squeal every time you stop, it really takes away from the kewl points.. Any suggestions?
PostPosted: Mon Jun 17, 2002 12:39 pm
Sounds like pad chatter. Try a liitle high temp rtv at all the caliper points that the back of the pad touches.
PostPosted: Mon Jun 17, 2002 1:04 pm
Copper grease on the back of the pads and a smear on the contact points either end.
PostPosted: Mon Jun 17, 2002 2:53 pm
Lusifer
That won't work for Val's type of driving. The stuff will melt and geton the pad or rotor.
PostPosted: Mon Jun 17, 2002 4:19 pm
Roy, If I'm lite or really heavy on the pedal it's quite. I should of did it right when you told me the day we had it apart. I should be getting my new shocks this week so I'll fix it then. Thanks for the help!
Val
PostPosted: Mon Jun 17, 2002 4:22 pm
There is some liquid stuff available that I've used for that very symtom. I first used it at a Mazda/GM dealership. It was prescribed by Mazda due to customer complaints on their new Mazdas brakes squealing.. It's a metallic looking liquid that soaks into the pads and does a good job of anti-squeal. I can try and hunt some down for you if you like.
SVT Slobra
PostPosted: Tue Jun 18, 2002 7:05 am
Chickenkiller,
Thanks for the offer, I'm going to take it apart this week when I put my new Bilsteins in. If I can't get it to stop then, I'll take you up on that offer.
Thanks Val
PostPosted: Tue Jun 18, 2002 11:47 am
I put the silicon on them before I put it back together. No squealing with mine.
PostPosted: Tue Jun 18, 2002 7:32 pm
I'll try it! thanks
Val
